After market vs stock cooler AMD
ok so has anybody used the stockcooler came with fx8350 ?
is it any good if i do not overclock the cpu ?
can we overclock with stockcooler >?
which aftermarket cooler is better Liquid Cooling or fan one  ?
and please suggest me a good me a good aftermarket cooler off this site http://goo.gl/bNMsr
I am using the stock cooler for now and its ok,  but it does get really loud
if you plan on over clocking get an after market cooler defenitely that cpu gets really hot
you can oc the with stock but its not that great
its really up to you what you would like to use
the cooler master hyper evo seems to be most recomendable for fan cooling , i plan on getting the h100i because i was originaly gonna get the h100.
