Aerocool syclone 2 and radiators
is there any benefit from the design of the aerocool syclone 2 or is it just aesthetics? and is there any way to install an effective dual radiator or bigger inside the case? or is it the type of case that needs external watercooling for decent radiators. im aware of the monster radiators but do they out perform a 45mm thick radiator or is it a gimmick? if they do, does it work good enough to be worth the extra money over a 45mm thick radiator? (by is it worth it i mean is it a similar performance per dollar to the 45mm thick radiator)
