Advise for nanokvm setup with 1440p?
Hey all,
I have a couple nanokvm devices.
The first one i have is hooked up to my unraid machine so display is not really an issue.
The second is plugged into my gaming pc in a second port. This isnt ideal as i cant mirror my main monitor to it. This will be due to my main monitor being 1440p and the device being able to only handle 1080p.
My question is, how can i duplicate my main monitor to the nanokvm at the same time? Would this involve a duplicator with EDID ability or am i kinda screwed?
Cheers
Some type of screen cap then feeding to a player on the 2nd screen?
That could work but I imagine that’s not exactly a cheap solution to my issue
I mean OBS is free …
Ah, I was thinking you were refering to a more elaborate solution with like a camlink or something of that nature
No just plugin the nanokvm and set it as a 2nd monitor then use something like obs to screen cap the primary screen and dump it to a full screen window on there. Guessing controlling it might be a bit rough but its one possible solution.
Yeah if I had a 4k monitor or similar the downsizing would work easier. The 1440p of the main monitor really limits my options it seems
What if you just lowered the resolution to 1080p while you are using the nanokvm?
That’s also a possibility however that would entail me to set it each time and that I know will become tiresome pretty quickly day after day
I had tried to just turn my main monitor off each time I left the PC… It would seem that it still somewhat sees a further item plugged in so causes issues there as well…
All in all not the experience I was hoping to have with the device with my main PC…
