Advice on upgrading my PC?
Hey guys,
I could really use some advice on upgrading my PC. Here is my current build:
  • AMD Phenom II X4 965 Black Edition
  • HIS Radeon 7850 2GB VRAM
  • MSi 970A-G46 Mobo
  • Raidmax 530W Modular PSU
  • 120 GB Mushkin Chronos SSD
  • 250 GB WD Hard Drive
The main parts I would like to upgrade are my CPU, PSU, and Graphics Card. I'm comfortable with spending around $350 for my graphics, $200-ish for my CPU, and $150 on my PSU max. So, what would you guys recommend? I'm also open to any suggestions on my other components, so feel free to tell me if anything else should be upgraded. Thanks a lot for the help!
Your PSU should be fine.  I wouldn't trust a FX-8350 with that motherboard, though.  If you're looking to spend 700 dollars upgrading your PC, I'd get something like:
http://pcpartpicker.com/p/1qcIH
Thanks for the reply. Would it be better to get a new mobo if it can't handle an FX-8350? Or is the FX-6300 also a good CPU?
Getting an 8 core CPU would be better.  If you're up for a motherboard change, something like this would be good:
http://pcpartpicker.com/p/1ZxbP
Definitely something I'll look into, although changing my mobo will be pretty tough. Thanks for the help.
