Advice On My First PC Build! [Italy]
hey there!! new to the forum :)
I've been wanting to jump in pc gaming for a while now. Finally saved up enough cash for my first rig!!!!!
I need advice! what do you think of this possible build..
http://it.pcpartpicker.com/p/4nRtf7
I'm open to change, my only problem is that I'm in Italy where prices and components are a bit different from the US
thanks in advance
  • my budget is 1000€
  • live in Italy, obviously use €uro ;P
  • I normally use Amazon.it but i think any european amazon ships to italy
  • don't have peripherals
  • I'll be using my Glorious computer manly for gaming
  • I'm open to overclocking, maybe a bit in the future though :D
  • no current plans on watercooling, manly cos it sounds expensive
  • I already have an OS
  • I'd like to have at least a steady 60 FPS
  • 1080p is fine for now, open to upgrade in the future (don't think 1440p monitors are in my budget right now)
  • I play all kind of games, especially after steam sales :D (not too fond of Beatemups though)
  • absolutely need to be ready by 11/10/15!!!!!!! Fallout 4!!!!!!!!!!!!!
hope this will help you help me ;)
It'd be super handy if you could answer some of these questions as the answers to some can heavily influence what parts are recommended to you: HYPERLINK WOA
I'll be back in like 30-60mins & will put together something based upon answers to those questions.
Kingston ssd are that cheap for a reason, http://www.anandtech.com/show/7763/an-update-to-kingston-ssdnow-v300-a-switch-to-slower-micron-nand
a good platter hdd is faster , no point of getting v300 ssd
