I am getting ready to build my first pc. I will primarily be using it for gaming and my budget is around $1050. Im just looking for some feedback on the build that I've made. Any comments or suggestions are welcome. Thank you.
That motherboard is poorly suited to overclocking, the Radeon HD 7870 XT is just about as powerful as the Radeon HD 7950, but for about $80 less, and Patriot Viper 3 2133 MHz RAM was $104 for 16 GB in four sticks (and they were black too) last I checked.
Got to agree with above post.. that mobo is not so good (get a 990fx chipset instead since you are going with the newer 8350 cpu) and that ram is downright expensive.
excactly he only needs that ram if serisly overclocking or hosting a server. you could just get 2 corsair vengence 2x4gb kits and that would be maybe 5-10 dollars cheaper.
Thank you to everyone for all of your suggestions. I've made a new build and took all of your advice into consideration. I changed the ram and the mobo, If you have anymore suggestions please let me know.
