Advice on CPU AMD 3700x or 9700K ( coming from a OC 7700k)
so been rocking a OC 7000k for a while and want to get into a 8core. thought about going 2700x but with 3rd gen Ryzen out figured might as well look at the 3700x. i do mostly gaming but starting to get into streaming and messing around with Linux/coding. ive kinda of talked myself into going AMD over intel because of this but wanted to hear other things
my inital build thoughts as im going to carry over my 1080ti FTW3 card from my current build
AMD https://pcpartpicker.com/list/YqRNXP
or
intel https://pcpartpicker.com/list/zxHfYT
thoughts ???
Hi Jay_c,
That FTW3 will rock nicely with either setup you choose.
Regarding your stated use case my suggestion might be a tad-bit biased but I feel also that it’s justified as well.
For context:
  • I have and use in my stable an [email protected] w/1080ti and it gets it done, no worries. It is a dedicated game machine. I do nothing else with it other than gaming except for bench-marking for comparisons. It is a nice machine very, very capable yet of being much more than its used for.
  • I have a Ryzen 7 2700x also with 1080ti, This is my daily driver machine and it gets used for all sorts of workloads, including running VM’s, gaming, work from home productivity etc. etc. It too gets the job done nicely, for all uses.
  • I have recently setup a Ryzen 7 3800x and have been pommeling it through the paces - This is an extremely nice setup and I’m confident, very capable of taking whatever I throw at it - no worries, gaming included.
TLDR;
If you had said gaming only I would have said go with the Intel system, but… My input based on your presented use case - would be to go with the Ryzen 7 3700X build. You will enjoy gaming no worries, and streaming too. You can run a VM or two (aka setup linux on a VM and have at it) You will be able to do pretty much any productivity workloads that you want to take on and have a very nice experience all around.
Welcome to the group - I’m sure others will be chiming in with their thoughts as well. Lot’s of good cats in this forum.
Save money on the Memory and get a good 3200 Set
Instead of a shitty/low end X570 Board I might look at a higher end X470 (or even B450)
You only lose PCIe 4.0 but gain soo much more. You have to be careful though and get either a Board that is Ryzen 3000 ready (MSI MAX) or one with a CPUless Flashing Feature (many MSI and Gigabyte Boards). You might want one with a 32MiB BIOS (just download a BIOS and look at the Size of the Board you’d like).
And I’d totally go for the Ryzen System and not the shittier 9700K, as that is something that will come to bite you later - same as 7600K vs Ryzen 1600X in more modern games.
