Advice on Build ($1500)
Current progress is here: http://au.pcpartpicker.com/p/1OoP2 . I'm mostly looking for advice on improvements and refinements, at this stage.
Hello guys, I'm a fairly new addition to this community and I'd like some advice on a build I'm going for.
For the sake of context, I'm an Australian student who is currently running a gaming PC with an 8500GT and a Q660. Needless to say, I'm looking for somewhat of an upgrade. As is stated in the title, I have a budget of around $1500, but I could probably manage to squeeze out a bit more. I have all of the peripherals I need for now, so that shouldn't be an issue.
I don't expect I'll be doing anything heavier than playing games. I don't focus too much on the graphical side of things (hence the lifespan of my current PC), and I can't see myself bothering with anything over 1080p at this stage. However, high frame rates are always a friend.
Can anyone offer some advice on how I can improve my build so far?
Thanks for the help.
GPU: HD 7970 or HD 7950.  They're cheap due to the new AMD R9/R7 release.
Mantle: I thought the Mantle API was open.  I was kind of suspecting that they should run on current cards.  Not too sure about this.
CPU: i5 3570k/4670k or FX-8350.  A lot of games I play are not optimized for multi-threading, so I went with the i5.
SSD: A Samsung 840 EVO should be good and quick.
RAM: At least 2x4GB(8GB total), preferably at 1600mhz.
Thanks for the help! I threw together a little test to see how I could get my prices, but... It seems I'm still awful at financing.
The build can be found at http://au.pcpartpicker.com/p/1O8AJ , and it would be fine if I lived in America... However, unfortunately, I'm an Australian. We live in a small pocket of technological stagnation, when it comes to these things.
Anywho, can you offer advice on how I can improve this build? Be it for more power or a lesser cost, I'm not sure if the parts I picked were quite right. Hopefully I'll be adding a CPU cooler as time goes on, as well.
I always hear about the horrible prices in Australia. Is it just a customs tax, or are you  not able to foward your mail?
P.S. with home premium, you will only be able to use about 13 GB of your RAM because of your vram. Just thought I would let you know.
I wish I could give you a proper answer on this, but to be honest, I'm not very sure. I can only imagine that it's partially due to the conservative nature of a lot of Australians, and their lack of interest in technology. If you need some context, our Mitt Romney was elected as PM this year. I'm looking forward to a good three or so years of absolute nothingness, as he has already cut significant funding to education and research. Idiot.
Anywho, the market is just smaller here, as the demand isn't as great. So I suppose it may just be a matter of Australia being seen as more expensive to send stuff over to, given the low returns. Maybe.
Ah, I'm a derp. I wasn't aware that the cap applied to Vram as well. I'll make amends and edit the original post to add the link. Thanks for pointing that out.
The memory cap is 16GB for Windows 7 with the home edition. http://goo.gl/S9K2we
Whatever the case, I may just go for Professional. Should I ever want to increase the amount of memory I have, then I won't have any issues.
Does anyone have any advice on what I can do with my build, at this stage? Anything you would change or improve upon?
You can save a bit of cash with a cheaper SSD:
Samsung 840 Series 120GB 2.5" Solid State Disk.  Slightly slower, but you're over your budget.  Still infinitely faster than a HDD.
You don't need so much wattage on a PSU if running on one GPU.  If you plan on overclocking and XFire, then the 750w will be a good choice.  Otherwise, XFX P1-650S-NLB9 should do you well.
Yeah, that is significantly better. I won't miss the 8 GB, and I'm sure the speed won't bother me too much. Thanks for that.
I struggled with the decision on the 750W for a little bit, but in the end decided that it's just better to be safe. Still, thanks for the help.
The build looks better now, and I may, perhaps, be able to squeeze my budget a bit higher so that I can afford it. Either way, does anyone else have any more input? Even if it's just for a slightly more expensive, yet far better component. At the moment, I'm having the most trouble with my memory choice. I'll probably drop down to 8 GB and buy an additional piece later, but does anyone have a better idea for my specific choice?
