Greetings folks. I'm living in China, and Dec 12th is like a big shopping craze day, similar to Nov 11th and I'll be purchasing a rig. I've been saving up for a while and technically, I don't have a budget limitation, but I'll be spending a max of 1500$, however, the prices here are slightly different than the US.
He's my desired build for the case, the peripherals are already present, I got a monitor, speakers, keyboard 'n' the rest...
Motherboard: Asus Sabertooth Z97 Mark 1 (Intel Z97/LGA 1150)
CPU: Intel i7-4790k Haswell (LGA1150 @4GHz 8M Cache)
RAM: Kingston Fury DDR3 1600 8GB x 2 (HX316C10FB/8)
HDD: Western Digital 1TB Black 7200RPM 64MB Cache (WD1003FBYZ) (for now, planning on an SSD later)
PSU: 600W PSU
Case: JONSBO QT01 (A black one)
VGA: EVGA GTX970 4G 1050-1178MHz /7010MHz 256bit
Sound card: Need a recommendation (for me to jack in my guitar/amp and play)
What might I improve here, and what kind of a cooling system might I apply to such a build? I honestly prefer a 120mm fan over water cooling, (several of them for that matter) because the case will be in my room and it will sometimes be left to process something while I sleep.
I'll be using this for 3D design, multimedia production (both audio and video) and gaming.
Any advice would be helpful. Thank you very much.
