need some advice on parts an finishing up my 3rd build
Out of the box can i update the gigabyte b550m ds3h Bios using the q flash with
the 5600x already installed or would i need to run it on a 3300x first ?
my build to be is black atom - AMD Ryzen 5 5600X, Radeon RX 6700 XT, Fractal Design Pop Mini Air MicroATX Mid Tower - PCPartPicker
or this version
PC Builder - AMD Ryzen 5 5600X, Radeon RX 6700 XT, Fractal Design Pop Mini Air MicroATX Mid Tower - PCPartPicker im still trying to decide
on the ram id either go with what in the build list or maybe either 4 x of
or 4 x of
iv currently got the mobo ,cpu , gpu, both nvme , aio ,case , fans , burner , fan hubs , heatsinks , usb c add-on card ,
mouse , keyboard , iv yet to get the ram , the 2tb ssd an monitor iv got a 650watt seasonic gold psu
but i want to get the evga 850 for power headroom unless the 650 is enough for a
10 to 15% oc on both cpu & gpu
im not sure wither the desired ram is best or one of the two other stated is better as id do like the 1.2volt option
your thoughts on ram , psu , 2tb ssd an monitor would be great thanks
fyi
the cpu is ok for my needs i got what i could at the time which was two 1/2 months ago if i had more cash at the time i
would have got the 5800x an i might later on but for now im sticking with it , an why so much ram i do hi rez image an
pix editing an creation 10000x10000 min at 200 to 300dpi an also vid editing an on my previous build i found the i did
better with 64gb over 32 as some of my projects chew up wards of 38 - 45gb , an why i prefer 1s over kit is above all
price i buy in chunks an buy when in stock an i have the cash which right now is coming up at the end of the month ill
have just about 115$ to use thats got to cover sh&tx
would either of these be a good pair with the gigabyte b550m ds3h
over either of the current picks in the build lists
2 x of https://pcpartpicker.com/product/wnbCmG/
or
or
2 x of https://pcpartpicker.com/product/hsWzK8/
or
2 x of https://pcpartpicker.com/product/sKXJ7P/team-t-create-classic-32-gb-2-x-16-gb-ddr4-3200-cl22-memory-
ttccd432g3200hc22dc01
or
a follow up question can 4 1s be manually tuned once in a system using memtest86-usb
on my two previous builds one has 64gbs va 2 x 32gb kits an 2nd va 4 x 16gb sticks without issue
tho it could just be lucky roll of the dice
