Getting ready for my first gaming rig build, what do you guys think about it? Feedback would be appreciated.
http://pcpartpicker.com/p/Meax
I am going to use my tv instead of buying a monitor.
Power supply is cutting it too close.
Rosewill wifi cards suck..
Other than that, looks good.
What resolution is your TV at?
http://pcpartpicker.com/p/MYf9
Switched some things around for the build to bring it down under $1500.00 without sacrificing performance. You should look into getting a monitor in the future though maybe something around 2560x1440 or 2560x1600 or (my new favorite) 2560x1080 because you will not be doing the GPU justice by displaying on a television.
Your TV has it's own way of processing input so that it can output @ 30/60 fps constantly at the picture it thinks looks nice for the resolution it was made for. So no matter how much you output through PC your AA/FXAA/FPS etc. will be limited and the signal will get a bit of lag from all the extra processing from the TV.
http://pcpartpicker.com/p/MYzT
720p
You need a more powerfull psu 650w+ to be comfortable
