http://pcpartpicker.com/p/P2gk
This is the build i have made myself and hope to get soon and it includes this monitor which i could not find on pcpart picker http://amzn.to/14XiNR1
The only thing i'm not sure about is the motherboard. Do you think it is the best i can get for the price. I have reached my budget limit but would consider spending an extra £10 on a better motherboard. Also i see the the system fan connectors are all at the top of the motherboard. My case comes with a rear and top fan but will i be able to install a front fan because of the distance? Also i have a question about the CPU . if i overclock the 8320 to 4ghz will it perform the exact same as a stock 8350? And last question will i be able to do crossfire with my 7950 in the future with my 750w power supply?
Thanks
woow much questions uhm..
first of all, the motherboard you chosed, is a good motherboard as long as you dont plan to overclock cause this board comes with a 4+2 power phase design, if you want a better board to overclock then go for the Asus M5A97 EVO r2.0 that comes with a 6+2 power phase.
But the problem is, if you plan to go crosfire, then you better go with a 990 FX chipser board realy. the asus 970 boards have pci-e 2.0 x16 and x4 so that means if you ever wanne runn a crosfire then the whole setup is gonne run at x8 speed. cause the x4 slot black one gonne size down the bandwidth of the x16 slot. to 4x 4+4 makes x8
so if you realy plan to crosfire 2 7950´s in the future go for a 990FX chipset board, like the Asus M5A99FX pro r2.0.
about the power supply, you need also a better power supply if you ever plan to crossfire and overclock youre system, i would suggest in that case a 950W 80+ gold.
grtz Angel
