I need help in picking some parts he wants to play BF4 at 60fps 1440p, he also wants it to be an ITX build
http://pcpartpicker.com/p/1Qehq
i need a good 1440p monitor
also any good simple keyboard and mice? suggestions?
My 7970(280x) can bearly push 50-55 fps in battlefield 4, max settings, at 1080p. If you Really want some incredible gpu horsepower, I would say to grab a 7990 while they're still around and still relatively cheap(if you can work a bit more into the budget). Also, personally I think the prodigy is too big for an mITX build, especially since there is an mATX version. Grab a Node 304 for sure. Your friend won't regret it.
would a 7990 fit in a node 304 ?
if you're looking for it 1440p monitor Logan and Windell did a video on $300 korean monitors.
Anything would fit into a node 304. They can fit GPU's up to 12.2 inches. So, yeah. Just make sure your psu of choice is no larger than 160mm and is not modular. Otherwise, your gpu wont fit.
