My girlfriend and I have decided to build the same gaming PC each.
We used to use the xbox 360, and both think the new consoles are a waste of money once compared to the PC.
What do you think of this selection?
http://uk.pcpartpicker.com/p/XxFhrH
I can't go much over the $600/£400 price (Which is just under what this build would come to)
I already have a hard drive, case and other peripherals, so this would be all I'd need in terms of actual components (I think?)
I'd like some opinions on it and maybe some advice on what I should swap out for something else if necessary, or if one of the components are overkill etc;
Perhaps it's all good, I'm not sure.
I've built a PC before, but as far as optimising it for gaming I'm a newbie.
The selection is based on what I've Learned through a few days of research, so apologies if I'm way off with this.
Obviously, given the budget, I'm not trying to build an incredible machine here, I'm just looking for something that will run most games well at 1080p, and also something that's somewhat future proof - hence the slightly bigger power supply than is necessary, and support for a second GPU via crossfire later on down the line.
Would very much appreciate some opinions and some advice.
Thanks very much!
EDIT: One more thing I forgot to mention. If possible, I might have to change the mother board.
I'm not sure weather it has one of the old PCI slots or not, and I'd have liked to have one of those for an older sound card I have.
Also, with the CPU, I was thinking of perhaps changing it for an one of the 6 core models in the FX line.
I wasn't sure weather that would give me much benefit now, but I've read a couple of times that it's a more future proofed chip - how true that is I don't know.
Obviously, I know true future proofing is impossible, but I'm trying to strike a balance so I have something that's reasonably priced, but that I' not going to be needing to change not long after I bought it - the same sentiment applying to all the parts, I suppose.
