Advice for FM2+ build
Hi this is my first post on Tek Syndicate and I will try to be quick.
I'm building a mid range Gaming PC for titles such as BF4 and Star Citizen. I live in Australia so most parts are more expensive and some parts aren't even available. I'm really confused about all the variables and would like to ask for your advice.
Here is my current List and the notes for each part
CPU
AMD Athlon II X4 760K ~$90-120 (The reason why I am using an Athlon is because they are cheaper than an APU and the IGPU is not needed. I am not too sure if this is a wise decision and this is the main reason I am asking.)
Motherboard
Gigabyte G1 Sniper A88X $150 (Probably the most solid A88X Motherboard IMO but it does have bad power phase. I'm not sure if it actually is a good motherboard because there probably is a more reliable A88x board out there.)
RAM
G.SKILL Sniper 1600 8GB (2x4GB) $105 (Cheap RAM and looks good on the motherboard. The other DIMMs at this price point are the same except for the colour and the actual chip)*
SSD
Samsung 840 Evo 120GB (About $5 more than a WD Black but I only want to load BF4 games quickly and transfer files. The 840 Pro is $35 more and I'd also like to ask if that is worth the extra money.)
CPU Cooler
Corsair H100i $150 ( Although it probably is overkill for an Athlon or 7850K the H80i is $20 cheaper and this could be used in a later build or for a Kraken G10)
Graphics Card
I have the Sapphire R9 280x in mind however it is $440. I was going to get an Asus VG248QE for the 1ms response time and upgradeability to G-Sync but That is $450 in Australia. So that has been knocked off the list and now I am using an old Acer AL1916W which is 19" 900p and 8ms response time. I really don't care about playing on ultra and I could be very happy playing on low in BF4 but as long as it is 1080p+ with resolution scale over 120%. Maybe an R9 270x Reference with a G10 and a good Water cooler? Or just a toxic 270x? This is the part that I am most confused on.
Case
Corsair 750D $200 Aesthetically pleasing, Can be used with other builds, Water cooling options and enthusiast case. I can downgrade if the budget requires it but currently I'm more worried about the main components
Power supply
Corsair RM650 $160 Quiet and efficient power supply. From the reviews that I have read, It is more reliable than say a CX series. Having Modular cables is an OCD thing that I really like and I doubt that the PSU will fail. Can also be used for future builds.
OS Trying to decide in-between 7, or 8.1. I had 8.1 on my old computer but windows 7 is more stable and user friendly. I have hear that some people get better performance on 8/8.1 and it does boot faster. Could someone clarify this part?
Keyboard
Ducky shine 3 Year of the snake. Heard a lot of good talk about this keyboard and I like the aluminium faceplate.
Mouse
Razer Ouroboros, Had a G700 but I prefer customisability. Probably a plastic consumerism trap so please suggest alternatives.
Audio
Apple EarPods Not kidding but I don't want to buy a headset. Although maybe next year I will save up for Razer blackshark.
So that sums up the parts but now I need to discuss my reasoning;
I chose the Athlon because a Kaveri GPU is too weak for BF4/SC and not really upgradeable. I may have to wait until Kaveri comes out and read the reviews but the Athlon looked very promising when I first saw it. I have heard rumours of an 8 core APU but I only really care about the GPU.
The motherboard looks very promising and the colour scheme really attracts me to it. Conventional CPUs don't use high frequency RAM so I decided that 1600 should be fine. If I do go with the Athlon and wait for a newer APU to be released in 2014 then it would be a good idea to go with Trident X at 2400. Could someone please clarify if 1600 is fine?
The price of the AMD graphics cards have increased because of litecoin mining and Nvidia does look like a viable option. However If I go with an APU now and grab a maxwell card + A G-Sync VG248QE next year that could be a good idea.
Most of my reasoning is only theoretical because this is my first build so I just wanted to get some advice from professionals.
Thank you.
http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=249435&action=wish_lists
+ monitor
It seems like you have a fairly reasonable budget so I don't really understand why you are choosing to build on a FM2 platform. It would seem better to me if you were to use a 990fx mobo, or indeed a H87/Z87, and get a better CPU that won't bottleneck that possible r9 280x/270x. Unless you're planning to upgrade to a Kaveri chip in the future then you will be much better off going for a slightly more expensive platform. The reason why the X4 II 760K is the best FM2 CPU you can get.
That might not be that well written so, in short, I'd ditch the FM2 platform and invest in something more upgradeable.
