Hello Guys,
Well, I'm going to build a new pc pretty soon and i want to ask you what you think about the parts that i choose?
The original website is in dutch but it's translated.
Please give me all of you oppinions and what to change and what not.
Ohh and btw my budget is around 1200 euro
Here is the link to the shop:
http://goo.gl/bHgdZM
Ratzzz
September 4, 2014, 8:44am
2
The kingston SSD is kind of meh ... recommend Samsung 840 evo SSD
And the MSI R9 290 GPU is somewhat loud and has warmer temps ... If you want something quieter and cooler running ... here are some GPUs to consider ...
Gigabyte Radeon R9 290 4GB WINDFORCE Video Card ..... $369
http://pcpartpicker.com/part/gigabyte-video-card-gvr929oc4gd
HIS Radeon R9 290 4GB IceQ X² Video Card ....................... $389
http://pcpartpicker.com/part/his-video-card-h290qmc4gd
Asus Radeon R9 290 4GB DirectCU II Video Card ................ $410
http://pcpartpicker.com/part/asus-video-card-r9290dc2oc4gd5
Sapphire Radeon R9 290 4GB Vapor-X Video Card ............... $448
http://pcpartpicker.com/part/sapphire-video-card-100362vxsr
Sorry I did not get the euro prices for you ... just USD
I had some trouble with Google translator and your link ... it stopped working when I tied to look items up at their website ...
other than that it looked pretty solid : )
edit:
I just want to add that I can not speak on if you are getting good prices because I have no idea what things cost in Europe.
Why do you need screws for fan mounting?
You might want to look into a higher wattage power supply if you want to overclock.
Get another SSD. The Kingston SSDNow V300 are using asychronous flash, resulting in very poor performance.
Other than that, looks like a good red/black build.
Okay guys i changed the ssd for a samsung evo. And thanks for the replies i really appriciate it! Also i chose msi because of 2 things: It is 30 euro cheaper then the others. And i don't mind loudness because i wear headphones anyway. Tge screws are for a other mod ;)
Ohh and btw what do you think about the asrock motherboard? People say it isn't good
They're so-so. Look into the Asus M5A99FX Pro R2.0
I already thought about getting a asus board but it would really ruin the color scheme. And getting a ROG board will be to expensive :(
Try the MSI 970 Gaming if you want a black and red scheme. It's quite new though, and may not be available.
The Gigabyte GA-970A-UD3P might be an option as it's mostly black.
I saw them but ther aren't 990fx right? While i want that socket (future water cooling/OC)
+ Msi has really bad board as i've heard
It's the 970 chipset, and I don't see why you couldn't get just a CPU block and do a custom loop.
The 970 Gaming from MSI is much better in terms of quality compared to the 970A-G43 and G46. It has much better power delivery and cooling
