Advanced System Care or CC Cleaner?
So, i've just purchased a legit copy of genuine Windows 7 Professional (I used to have a pirated copy of genuine Windows 7 Ultimate) which really sucked for awhile, i've seen lots of stability way more than the crappy pirated version.. so what i did is using Advanced System Care to Fix and Organize my registry settings and cleaning up the windows temp files and junks.. but i've heard cc cleaner is also good too.. (BTW) i have a Orginal Key of Advanced System Care i found that program quite helpful also .. would u recommend me to install a Driver Detector Software? reply thanks
Advanced system care came out with a program called driver booster . It seems to work okay. I also use a free version of cc cleaner, malawarebytes  as a secondaries to my advanced system care. Another important part of that package is smart defrag with system optimizing, which is really good if your running only hdds.
I think highly of the iobits uninstaller also. All in all, Iobit has been putting out some very solid programs.
Didn't know of Advanced System Care before so I had a look at it. Sweet Jesus it's full of crapware. I was slightly annoyed by CCC adding a little bit of crap to their installation, but hey they need to live so I accepted that. But almost half of ASC was things you weren't asking for and it didn't even uninstall clean in the end. My opinion is avoid it, and I'll be wary of whatever else they've made no matter how good that might be. CCleaner is an honest and well laid out little program, no matter how little I use that either (especially not its registry "cleaning" part).
Actually its one of the best all in one tools kits out there. Cant help it ,if you dont know how to use it.
