So I recently switched to an r9 280x from gtx560. In Premiere cs6 I was able to have my GPU do all the rendering which saved me a great deal of time on videos. So I was wondering how I can add my new GPU to the "opencl_supported_cards" list. I have tried different names for the card, but I cannot get Premiere to recognize it for me to chose the GPU as an option instead of that damned "Mercury Playback software only" for rendering.
Please look down at my other post for further information
Okay so despite being an idiot with command prompt, I was finally able to get GPUSniffer to work after finally seeing Logan do everything on the INBOX.EXE.
So GPUSniffer did not work correctly for me. Here is what I get in command prompt:
Did not find any devices that support GPU computation
I put the name of the card exactly as shown in command prompt into the opencl_supported_cards" list but it did not work. I also tried it without the word "series" at the end. Nothing worked. I, also, could not find anything online again using some of the terminology taken from the command prompt.
Again if anyone has any ideas, I'd greatly appreciate it. Thanks.
Tahiti is the codename for our GPU. I have the sapphire 280x vapor-x. It should already be in there. Below is what is in my opencl_supported_cards.txt from Premiere CC. Scrubbing and palayback is flawless
Bonaire Capeverde Cayman Devastator Hawaii
Oland Pitcairn Tahiti Turks Spectre
Intel Iris Graphics 5100 Intel Iris Pro Graphics 5200
This is what i get out of GPUSniffer. Make sure AMD Catalyst is installed properly. I disable catalyst from startup though since heavy loading and It not neccesary once you apply any settings if any.
C:\Program Files\Adobe\Adobe Premiere Pro CC 2014>GPUSniffer --- OpenGL Info --- Vendor: ATI Technologies Inc. Renderer: AMD Radeon R9 200 Series OpenGL Version: 4.4.13084 Compatibility Profile Context 14.301.1001.0 14.301.100 1.0 GLSL Version: 4.40 Monitors: 1 Monitor 0 properties - Size: (0, 0, 1680, 1050) Max texture size: 16384 Supports non-power of two: 1 Shaders 444: 1 Shaders 422: 1 Shaders 420: 1
--- GPU Computation Info --- Found 1 devices supporting GPU computation. OpenCL Device 0 - Name: Tahiti Vendor: AMD Capability: 1.2 Driver: 1.2 Total Video Memory: 3072MB
