Adobe Flash - Catch 22, need help
I have a piece of hardware that uses a web management interface, annoyingly this requires Adobe Flash.
I’ve now got an update for this device which means the web management interface will no longer require Adobe Flash to use, however I can’t access the web management interface in order to install the update because of its current requirement for Adobe Flash
I’m loathe to scour the internet myself because who knows what nasties I’d find.
Does anyone have experience with an alternative I can use so that I can get this update installed?
Probably your best option is to install an older version of a web browser which has flash included, then enable flash via “Enterprise Enablement”
Enterprise enablement tutorial:
https://kb.vmware.com/s/article/78589
Old versions of firefox, you probably want firefox 80(ish):
https://ftp.mozilla.org/pub/firefox/releases/
Thanks so much.
With that information I was able to get it up and running.
I set this all up on a VM so that it could be powered off (thus reducing the security risk) most of the time and only booted up when I need access to the devices in question.
I have 3 identical devices that I can now update.
