I was planning to add more fans to my evolution case but not sure which fans I should use. Should I just add the same kind of fans that he case comes with (turbine fans) or should I go with a totally different one?
If I were you I would put some more Cougars in there, they are great fans. If you live in the U.S. you can pick up a four pack for pretty cheap http://www.newegg.com/Product/Product.aspx?Item=N82E16835553008 they also come in black if that better suits your color palette.
