Hello. I am new to overclocking and just got a 4770k. I got it to 4.4ghz at 1.275v and 3.5 ring bus. The only things I changed in the bios are core ratio, ring bus, and vcore voltage. Everything else is default/auto. I think its stable enough there, so I went to change the voltage from manual to adaptive and it blue screened at the windows login.
Any suggestions to fix it so that Adaptive mode will work?
thanks.
