I was searching everywhere for an active adapter from HDMI 2.1 to displayport 1.4 that could be used to connect a Playstation 5 (which not sure when or if I’ll find one ) to my LG 27GN950-B, the monitor supports HDMI2.0 which locks at [email protected] while the monitor can reach [email protected] with the DisplayPort 1.4 port.
any way, I couldn’t find such an adapter and I was wondering if something like that exists? is it even possible?! and if this is possible could Wendell build it?
The final plan is to use my soon to arrive L1KVM DP1.4 with the whole setup.
Hi - Did you ever figure this out? I’m about to connect a PS4 Pro to a L1KVM DP1.4 and was in the search for an HDMI 2.0 to DP 1.4. I settled on the HDMI 2.0 to DP 1.2 (since my monitors are DP 1.2 anyway) from Foinnex, but not sure how that’s going to work out. Thanks.
There’s DP 2.0 to HDMI 2.1 in the opposite direction the OP wanted, but it’s in a chipset state and not yet a product.
The primary problem with HDMI 2.0 to DP 1.4 is that Freesync/Gsync displays are unsupported because the firmware designers for the ONLY device from SIIG couldn’t get timings to play nice on VESA Adaptive Sync enabled monitors.
