If memory serves, about 20 years ago Windows had a feature called “Active Desktop” that allowed the desktop “wallpaper” to be an interactive surface — built with web technologies — instead of a static image. You could style it any way you want, display static text, RSS feeds, and arbitrary web pages on different parts of the desktop. The desktop wallpaper was basically a web page.
Is there anything remotely resembling “Active Desktop” available for Linux?
Ideally, what I’m aiming for is a desktop that looks/behaves like this:
- a single wide-screen — no less than 16:9 aspect ratio
- can’t use multiple physical displays for space reasons
- subdivided (horizontally) into three sections
- the left column takes up about 15% of the width of the screen
- the middle column takes up 70%
- the right column takes the remaining 15%
- content in all three columns changes over time
- the centre changes once per login
- the sides change continuously and unpredictably
- notifications and system events can come in randomly
- low-res IP camera feeds and other video could stream in at up to 60 frames per second
- the remainder probably wouldn’t refresh more than once per second
- if any dynamic content in any of the panels warrants further scrutiny, I would like to be able to hover over it for a ‘tooltip’ that provides more info, or click on it to load full info into one of the three columns
- by default, applications that are launched should size themselves to overlay the middle column — indeed, they would ideally think that the middle column is the “whole screen” for the purpose of maximising
- it is desirable to maintain “borderless full-screen” as an option for video playback
- with the exception of full-screen video playback, it is envisaged that both left and right columns should otherwise always remain visible
- this setup would make a full-width ‘panel’ at the top of the screen (a la Gnome 3) redundant and unnecessary
I’m not concerned about the performance, memory/power consumption or security issues associated with the concept of “web on desktop” — none of those are relevant to my use case. Plenty of grunt, RAM and power is available, and all content is generated on the intranet.
Since I doubt that a ‘perfect’ solution already exists, I’ll probably need to roll together some combination of distro/desktop environment/display manager/window manager/application, and customise a bunch of things to get close to the above. That’s fine. Any suggestions — for any of the components — would be appreciated.
I’m also open to solutions or ideas out of left field… even if they address just one part of the problem.
Cheers!
