ACS Override Patch Debian12
Howdy,
I’ve hit a snag while setting up PCIe Passthru.
I have 2 nvidia cards, a 1080, and I think a 970.
Trouble is, both of them are in IMMOU group 1.
I might be able to get away with using the iGPU, but the performance isn’t exactly comparable.
My goal in this whole ordeal is to step away from Windows, but still be able to duelboot / spin windows up in a VM for games that I can’t get to work in linux.
For that, I’m passing thru an entire nvme, and the 970.
I was unable to find any other virtualization options in my BIOs, which I guess leads me to applying the ACS Override patch.
I’ve never patched/rebuilt a kernel before.
Debian12 ships with 6.1.0-10, and I’m struggling to find where to even get the ACS Override patch, so I’m at a loss.
For transparency:
CPU: i7-8700(non-k)
MB: MPG Z390 GAMING EDGE AC (ms-7b17)
BIOS: 7B17vAC (newest 2022-10-24)
lspci -v:
00:00.0 Host bridge [0600]: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers [8086:3ec2] (rev 07)
	DeviceName: Onboard - Other
	Subsystem: Micro-Star International Co., Ltd. [MSI] 8th Gen Core Processor Host Bridge/DRAM Registers [1462:7b17]
	Flags: bus master, fast devsel, latency 0, IOMMU group 1
	Capabilities: [e0] Vendor Specific Information: Len=10 <?>
	Kernel driver in use: skl_uncore
	Kernel modules: ie31200_edac
00:01.0 PCI bridge [0604]: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 07) (prog-if 00 [Normal decode])
	Subsystem: Micro-Star International Co., Ltd. [MSI] 6th-10th Gen Core Processor PCIe Controller (x16) [1462:7b17]
	Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 2
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 4000-4fff [size=4K] [16-bit]
	Memory behind bridge: b5000000-b60fffff [size=17M] [32-bit]
	Prefetchable memory behind bridge: a0000000-b1ffffff [size=288M] [32-bit]
	Capabilities: [88] Subsystem: Micro-Star International Co., Ltd. [MSI] 6th-10th Gen Core Processor PCIe Controller (x16) [1462:7b17]
	Capabilities: [80] Power Management version 3
	Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [a0] Express Root Port (Slot+), MSI 00
	Capabilities: [100] Virtual Channel
	Capabilities: [140] Root Complex Link
	Capabilities: [d94] Secondary PCI Express
	Kernel driver in use: pcieport
00:01.1 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) [8086:1905] (rev 07) (prog-if 00 [Normal decode])
	Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) [1462:7b17]
	Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 2
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: 3000-3fff [size=4K] [16-bit]
	Memory behind bridge: b3000000-b40fffff [size=17M] [32-bit]
	Prefetchable memory behind bridge: 80000000-91ffffff [size=288M] [32-bit]
	Capabilities: [88] Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) [1462:7b17]
00:02.0 Display controller [0380]: Intel Corporation CoffeeLake-S GT2 [UHD Graphics 630] [8086:3e92]
	DeviceName: Onboard - Video
	Subsystem: Micro-Star International Co., Ltd. [MSI] CoffeeLake-S GT2 [UHD Graphics 630] [1462:7b17]
	Flags: bus master, fast devsel, latency 0, IRQ 155, IOMMU group 0
	Memory at b2000000 (64-bit, non-prefetchable) [size=16M]
	Memory at 70000000 (64-bit, prefetchable) [size=256M]
	I/O ports at 5000 [size=64]
	Capabilities: [40] Vendor Specific Information: Len=0c <?>
	Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [d0] Power Management version 2
	Capabilities: [100] Process Address Space ID (PASID)
	Capabilities: [200] Address Translation Service (ATS)
	Capabilities: [300] Page Request Interface (PRI)
	Kernel driver in use: i915
	Kernel modules: i915
00:08.0 System peripheral [0880]: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model [8086:1911]
	Subsystem: Micro-Star International Co., Ltd. [MSI] Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model [1462:7b17]
	Flags: fast devsel, IRQ 11, IOMMU group 3
	Memory at b4242000 (64-bit, non-prefetchable) [disabled] [size=4K]
	Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
	Capabilities: [dc] Power Management version 2
	Capabilities: [f0] PCI Advanced Features
00:12.0 Signal processing controller [1180]: Intel Corporation Cannon Lake PCH Thermal Controller [8086:a379] (rev 10)
	Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH Thermal Controller [1462:7b17]
	Flags: fast devsel, IRQ 16, IOMMU group 4
	Memory at b4241000 (64-bit, non-prefetchable) [size=4K]
	Capabilities: [50] Power Management version 3
	Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
	Kernel driver in use: intel_pch_thermal
	Kernel modules: intel_pch_thermal
00:14.0 USB controller [0c03]: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller [8086:a36d] (rev 10) (prog-if 30 [XHCI])
	Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH USB 3.1 xHCI Host Controller [1462:7b17]
	Flags: bus master, medium devsel, latency 0, IRQ 127, IOMMU group 5
	Memory at b4220000 (64-bit, non-prefetchable) [size=64K]
	Capabilities: [70] Power Management version 2
	Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
	Capabilities: [90] Vendor Specific Information: Len=14 <?>
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:14.2 RAM memory [0500]: Intel Corporation Cannon Lake PCH Shared SRAM [8086:a36f] (rev 10)
	Subsystem: Intel Corporation Cannon Lake PCH Shared SRAM [8086:7270]
	Flags: fast devsel, IOMMU group 5
	Memory at b423a000 (64-bit, non-prefetchable) [disabled] [size=8K]
	Memory at b4240000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.3 Network controller [0280]: Intel Corporation Cannon Lake PCH CNVi WiFi [8086:a370] (rev 10)
	DeviceName: Onboard - Ethernet
	Subsystem: Intel Corporation Cannon Lake PCH CNVi WiFi [8086:02a4]
	Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 6
	Memory at b4234000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [c8] Power Management version 3
	Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
	Capabilities: [80] MSI-X: Enable+ Count=16 Masked-
	Capabilities: [100] Null
	Capabilities: [14c] Latency Tolerance Reporting
	Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
00:16.0 Communication controller [0780]: Intel Corporation Cannon Lake PCH HECI Controller [8086:a360] (rev 10)
	Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH HECI Controller [1462:7b17]
	Flags: bus master, fast devsel, latency 0, IRQ 156, IOMMU group 7
	Memory at b423f000 (64-bit, non-prefetchable) [size=4K]
	Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [a4] Vendor Specific Information: Len=14 <?>
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:17.0 SATA controller [0106]: Intel Corporation Cannon Lake PCH SATA AHCI Controller [8086:a352] (rev 10) (prog-if 01 [AHCI 1.0])
	DeviceName: Onboard - SATA
	Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH SATA AHCI Controller [1462:7b17]
	Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 128, IOMMU group 8
	Memory at b4238000 (32-bit, non-prefetchable) [size=8K]
	Memory at b423e000 (32-bit, non-prefetchable) [size=256]
	I/O ports at 5090 [size=8]
	I/O ports at 5080 [size=4]
	I/O ports at 5060 [size=32]
	Memory at b423d000 (32-bit, non-prefetchable) [size=2K]
	Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
	Capabilities: [70] Power Management version 3
	Capabilities: [a8] SATA HBA v1.0
	Kernel driver in use: ahci
	Kernel modules: ahci
00:1b.0 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port #17 [8086:a340] (rev f0) (prog-if 00 [Normal decode])
	Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH PCI Express Root Port [1462:7b17]
	Flags: bus master, fast devsel, latency 0, IRQ 124, IOMMU group 9
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: [disabled] [16-bit]
	Memory behind bridge: b6300000-b63fffff [size=1M] [32-bit]
	Prefetchable memory behind bridge: [disabled] [64-bit]
	Capabilities: [40] Express Root Port (Slot+), MSI 00
	Capabilities: [90] Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH PCI Express Root Port [1462:7b17]
	Capabilities: [a0] Power Management version 3
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [140] Access Control Services
	Capabilities: [150] Precision Time Measurement
	Capabilities: [220] Secondary PCI Express
	Capabilities: [250] Downstream Port Containment
00:1d.0 PCI bridge [0604]: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 [8086:a330] (rev f0) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 125, IOMMU group 10
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	Memory behind bridge: b6200000-b62fffff [size=1M] [32-bit]
00:1f.0 ISA bridge [0601]: Intel Corporation Z390 Chipset LPC/eSPI Controller [8086:a305] (rev 10)
	Subsystem: Micro-Star International Co., Ltd. [MSI] Z390 Chipset LPC/eSPI Controller [1462:7b17]
	Flags: bus master, medium devsel, latency 0, IOMMU group 11
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
	DeviceName: Onboard - Sound
	Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH cAVS [1462:7b17]
	Flags: bus master, fast devsel, latency 32, IRQ 163, IOMMU group 11
	Memory at b4230000 (64-bit, non-prefetchable) [size=16K]
	Memory at b4100000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: [80] Vendor Specific Information: Len=14 <?>
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_cnl
00:1f.4 SMBus [0c05]: Intel Corporation Cannon Lake PCH SMBus Controller [8086:a323] (rev 10)
	Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH SMBus Controller [1462:7b17]
	Flags: medium devsel, IRQ 16, IOMMU group 11
	Memory at b423c000 (64-bit, non-prefetchable) [size=256]
	I/O ports at efa0 [size=32]
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller [8086:a324] (rev 10)
	Subsystem: Micro-Star International Co., Ltd. [MSI] Cannon Lake PCH SPI Controller [1462:7b17]
	Flags: fast devsel, IOMMU group 11
	Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (7) I219-V [8086:15bc] (rev 10)
	Subsystem: Micro-Star International Co., Ltd. [MSI] Ethernet Connection (7) I219-V [1462:7b17]
	Flags: bus master, fast devsel, latency 0, IRQ 126, IOMMU group 11
	Memory at b4200000 (32-bit, non-prefetchable) [size=128K]
	Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Kernel driver in use: e1000e
	Kernel modules: e1000e
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP104 [GeForce GTX 1080] [10de:1b80] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: Micro-Star International Co., Ltd. [MSI] GP104 [GeForce GTX 1080] [1462:3366]
	Flags: bus master, fast devsel, latency 0, IRQ 164, IOMMU group 2
	Memory at b5000000 (32-bit, non-prefetchable) [size=16M]
	Memory at a0000000 (64-bit, prefetchable) [size=256M]
	Memory at b0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at 4000 [size=128]
	Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
	Capabilities: [60] Power Management version 3
	Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Legacy Endpoint, MSI 00
	Capabilities: [250] Latency Tolerance Reporting
	Capabilities: [128] Power Budgeting <?>
	Capabilities: [420] Advanced Error Reporting
	Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
	Capabilities: [900] Secondary PCI Express
	Kernel driver in use: nvidia
	Kernel modules: nvidia
01:00.1 Audio device [0403]: NVIDIA Corporation GP104 High Definition Audio Controller [10de:10f0] (rev a1)
	Subsystem: Micro-Star International Co., Ltd. [MSI] GP104 High Definition Audio Controller [1462:3366]
	Flags: bus master, fast devsel, latency 0, IRQ 17, IOMMU group 2
	Memory at b6080000 (32-bit, non-prefetchable) [size=16K]
	Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [78] Express Endpoint, MSI 00
02:00.0 VGA compatible controller [0300]: NVIDIA Corporation GM204 [GeForce GTX 970] [10de:13c2] (rev a1) (prog-if 00 [VGA controller])
	Subsystem: ASUSTeK Computer Inc. GM204 [GeForce GTX 970] [1043:853f]
	Flags: bus master, fast devsel, latency 0, IRQ 165, IOMMU group 2
	Memory at b3000000 (32-bit, non-prefetchable) [size=16M]
	Memory at 80000000 (64-bit, prefetchable) [size=256M]
	Memory at 90000000 (64-bit, prefetchable) [size=32M]
	I/O ports at 3000 [size=128]
	Expansion ROM at b4000000 [virtual] [disabled] [size=512K]
	Capabilities: [258] L1 PM Substates
02:00.1 Audio device [0403]: NVIDIA Corporation GM204 High Definition Audio Controller [10de:0fbb] (rev a1)
	Subsystem: ASUSTeK Computer Inc. GM204 High Definition Audio Controller [1043:853f]
	Flags: bus master, fast devsel, latency 0, IRQ 18, IOMMU group 2
	Memory at b4080000 (32-bit, non-prefetchable) [size=16K]
03:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983 [144d:a808] (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd SSD 970 EVO [144d:a801]
	Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0, IOMMU group 12
	Memory at b6300000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 00
	Capabilities: [b0] MSI-X: Enable+ Count=33 Masked-
	Capabilities: [148] Device Serial Number 00-00-00-00-00-00-00-00
	Capabilities: [158] Power Budgeting <?>
	Capabilities: [168] Secondary PCI Express
	Capabilities: [188] Latency Tolerance Reporting
	Capabilities: [190] L1 PM Substates
	Kernel driver in use: nvme
	Kernel modules: nvme
04:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO [144d:a80a] (prog-if 02 [NVM Express])
	Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO [144d:a801]
	Flags: bus master, fast devsel, latency 0, IRQ 16, NUMA node 0, IOMMU group 13
	Memory at b6200000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
	Capabilities: [b0] MSI-X: Enable+ Count=130 Masked-
	Capabilities: [168] Alternative Routing-ID Interpretation (ARI)
	Capabilities: [178] Secondary PCI Express
	Capabilities: [198] Physical Layer 16.0 GT/s <?>
	Capabilities: [1bc] Lane Margining at the Receiver <?>
	Capabilities: [214] Latency Tolerance Reporting
	Capabilities: [21c] L1 PM Substates
	Capabilities: [3a0] Data Link Feature <?>
As a follow up
I initially ignored the possibility of using my chipset pcie, but after getting yelled at for a while I ordered a raiser resolving my issue.
