There are a few motherboards which include a Display-port in port, to inject the video signal into a Thunderbolt port. I know some of the old X99 boards would use it, and I’ve seen a few AMD boards do this as well. I’m wondering if it is possible to access this video signal via software.
What I have in mind is a streaming PC with a displayport in which one could connect a console or a separate PC. The video signal would be displayed within a window on the PC’s monitor.
I know you could use a capture card, but I would like a PiP view rather than passing through to a second monitor.
Thoughts?
Many monitors and tv’s offer this feature. I’d start there as the cost would likely be similar to buying a new motherboard.
Sure, replacing the monitor is likely a cheaper, and definitely a more reliable option, but it’s not as fun. One benefit of doing it in software on the PC rather than through the monitor is for easy resizing/relocating.
That’s not gonna work because injecting the signal in the Thunderbolt port doesen’t mean it’s going through the system. What that’s going to do is pass through the signal and have it come out of the Thunderbolt port alongside the USB signal from the PC.
You need a capture card to do that and maybe have a PiP window with OBS.
