Return to Level1Techs.com
Access dsl modem behind opnsense
#1
this is my network setup:
dsl1(192.168.100.0/24)>pppoe1>wan gateway>lan(192.168.0.0/24)
dsl2(192.168.200.0/24)>pppoe2>wan gateway2>lan2(192.168.1.0/24)
as the title says what i want to do to is to access dsl modems or simply be able to talk to <192.168.100.0> and <192.168.200.0> from my lan (192.168.0.0)…
because i have two different gateways using the outbound NAT rule in firewall doesn’t work…(that i found out before in pfsense)…
the thing is on pfsense with some simple allow rules in firewall (allow access to <wan1modem net (192.168.100.0/24)> from lan ) it would work and i had access to the modems but the same setup doesn’t work on opnsense for some reason …
i did some googling couldn’t find anything useful some help would be appreciated…
some additional info:
inerfaces:
lan net > (192.168.0.0\24)
lan2 net >(192.168.1.0\24)
wan > pppoe1
wan2 > pppoe2
wan1modem net > (192.168.100.0\24)
wan2modem net > (192.168.200.0\24)
modem 1 has static ip of 192.168.100.1
modem 2 has static ip of 192.168.200.1
i want access from lan net to wan1modem net and wan2modem net…
