This is going to be my second build, please rate it out of 10 and maybe change something. My budget is $700 including shipping and taxes. I will be using this to play heavy games like BF3 online, Skyrim, Farcry, crysis, etc.
Thermaltake TR2 W0070 430W ATX12V v2.3 Power Supply
No it would not but I'd recommend the 6300 as the Phenoms are starting to show their age. If you're looking to save a couple dollars, grab the white version of the source 210 and also find a cheaper mobo since you won't be crossfiring.
Hey! One thing I would look at is maybe getting some faster ram (if you can squeeze it in the budget). Like 1600? My friend has DDR3 1333 and it bogs his system down quite a bit.
I thought RAM speed only made a big difference if you have an intergrated GPU? There's a 2% increase in overall performance from 1600 to 2400, according to a thread on tomshardware.
