do you trust ibuypower.com? do they have good customer support? do they make good qualitie products?
Just build your own pc. I'm sure all the members here can help you out. But to answer your question yes their pretty good but you can build your own pc for cheaper.
I have bought 2 Laptops from ibuypower, they are very reliable. I would recommend them if you are buying a laptop. If you want a desktop I suggest you just build it.
^^ agreed
yeah build your own; its cheaper :D
if your not up to building one then go with them because my friend bought an ibuypower off newegg for 500 bucks and it seems like a decent gaming comp, he mainly plays wow. http://www.newegg.com/Product/Product.aspx?Item=N82E16883227130
there pretty good i would rather build it myself
but if your not up to that task then go buy it but i would rather let tj harlow build it for me instead he is cheaper and better
i trust cyberpower and didgital storm more than ibuypower
If you don't know then I see it go two ways, GET THE FUCK OFF THESE FORUMS CAUSE ALL THESE GUYS WILL GIVE YOU SUCH BS ADVICE, or buy ibuypower, or go to youtube and watcht he tuts on how to build.
Xezmer wrote 33 minutes ago ยป
If you don't know then I see it go one option , GET THE FUCK ONTHESE FORUMS CAUSE ALL THESE GUYS WILL GIVE YOU SUCH AWESOME ADVICE
fixed
also this isnt a place ot get Bs advice its just some of the users here are absolute noobs
what i said doesn't need to be fixed.
i'm a perfectionist.
lol bitch kid over doing it...more like a child..not a student
just make your own pc so you can learn something and put all the parts you want and you can also put it up on youtube and show other how you did it.
