hi guys i have built a system a while back now and been having some issues with the build in the frames per second area in games. i would realy like to fing the problem here as i know i should be getting higher fps. for example in bf3 1920x1080 at ultra preset im getting around 25-130 fps but the real problem is my average is about 35-45 fps and it stays at the lower end of that margin. i also have noticed that my gpu usage is never above 50% and cpu never goes above 60% and has left me puzzled as benchmarks seem to be alot higher than my results. my full system specs are:
bitfenix prodigy
a10 6800k 4.1ghz @ 4.7ghz(OC) with corsair h100i
8gb hyper x beast 2400mhz ram
FM2A75M-ITX R2.0 mobo
EVGA GTX 770 sc acx (clean install of the 320.49 drivers)
ADATA 128gb SSD
500gb seagate barracud hybrid drive (Dont ask :P)
windows 8 64bit
Akasa Venom 550w Modular '80 Plus' Power Supply
i have searched and searched and have found no conflict in these parts but im a noob when it gets technical so if anyone could please take the time to help me out as i know there are some smart guys on here that proberbly see it straight away...
it is the same with AA of ans AS x1 plus no motion blur and actualy i get the same fps in ultra as i do in the low preset......? its why im so confused
I would have said the APU was holding you back, it's a low end CPU. If you got lots of overtime, I would suggest upgrading your platform. Your PSU is more than enough for your system.
If you're using an mITX system (judging by your FM2 mobo), I would recommend an i5 and your choice of mITX mobo.
That APU isn't a bad cpu for the average person's usage. It is just under the i3 in performance. However, even the i3 would bottleneck the 770. I would say go with something like a 8350. I don't know if you would have the bottleneck or not on a 6300.
But there are not really any good mini-itx mobos for AM3+ The bitfenix prodigy can only have mini itx. So he could buy a new case if he wants the 8350, which is better.
Considering the 6800k is higher-clocked, they should be pretty much on par.
Nonetheless, both don't really exceed the performance of an AMD Phenom (II x4). Pairing this with a 770 is a little bit too much and will indeed result in a bottleneck. The 760 is probably as far as you could go.
yes the psu has 45 amps with a 12v rail and i think im going to get the haswell i7 4770k and evga z87 stinger when its out and just make do with what i got for now still a while till battlefield 4 anyways so not much of a rush
