A10-6800K Bottleneck
Howdy Guys,
i recently bought an A10-6800K + HD7750 and im really happy with it.
It fits my gaming needs perfectly! But my question is would the 6800K bottleneck a high-end GPU like the R9 270X?
And if it does how bad is the impact. Im concerned that i want to play Battlefield 4 on Ultra as soon as i see it for the first time and have no choice on upgrading ;)
Greetings from Munich,
ThePapanoob
Bottleneck with decent gpu like 270x,  no. It will be all good. Something like a 780/titan/r920x yeah maybe in some titles. If you are looking at the 270/280 models, just grab a 7 series - 7950/7970/7870xt etc. Same cards as the r7/r8 series & at a lower price.
Just oc the shit out of the apu if you ever notice any drop in frames. Those things can reach some real high oc's even on midrange boards.
Thanks for the reply! :)
I know they overclocked it like crazy (~8GHz on all Cores!) and thats quite pleasing to hear!
i looked the prices for the 7 series up and the 7970 is around 250€ and the r9 270x is at 200€
now that confuses me!
270x same as 7870
280x same as 7970
ah thanks for making that clear.
i checked the prices again and i can get an asus direct cu2 7870 for 185€ and an asus direct cu2 r9 270x for 190€ wich is interesting :P
Just make shure its not the 7970 direct cu2 'top' vershon its voltage locked and had a lot of problems.
i think ill stick with the 270x because 5€ its not even a meal at mc donalds...
Sure these APUs have shown to be hella stable with overclocking, but 8GHz is not a viable option since liquid nitrogen is not the viable cooling system you would use XD Sure shows that with a very, very good liquid cooling system you could get up to 5GHz or so. That's still freaking awesome.
i know! its currently the world record (if it hasnt already been topped) and i'm going to install a custom loop next week so i think i can go pretty near the 5GHz since im going to use a 240mm and a 120mm radiator :D
At least not in Germany, in Southern Spain for instance a mcmenu is 4 EUR...
270x is a good choice, it's the sweet spot for price/performance in higher end GPUs, and AMD GPUs can do very cool things in linux, especially if you're running a bleeding edge cocktail. It's basically a 4.5 TFlops co-processor (about twice of the performance of a 2500 EUR+ Tesla card), and in linux (with hardware virtualization enabled systems), it's as flexible as a Xeon Phi (which is still 1500 EUR+ and doesn't work in linux quite yet as it should), for a fraction of the cost.
The more high end graphics card you get, the more noticible differense you will see between CPUs. The 6800k will do as fine as high end CPUs when having lower end cards than a 7870 or around that, but if you get an even better card, it's really not worth keeping the 6800k as you lose more and more frames due to it. Basically you bottleneck.
https://www.youtube.com/watch?v=qIT9uLDjZcg
Most of the time, the difference will not be visible to the human eye. Bottlenecking is more of a marketing thing than a real issue.
You can game modern games at full blow with a Pentium D if you have a newer graphics card, only very few games (Minecraft, Metro Last Light) benefit from a CPU that outperforms a 6-7 year old CPU.
Isn't the 280x a 7970 Ghx Edition
Don't forget Skyrim
My point was kinda referring to that particular video ^-^
Not much change when having something around a 7870 or lower end, but when having a more higher end there was a very noticible differense of 20+ frames. However I don't see those 20 FPS needed when you're already well above playable framerates.. but oh well c:
