Gnash
April 21, 2013, 8:45pm
1
Title says it all. Which would yield better performance?
A10-5800k crossfired with Radeon 6670
Phenom II x4 965 BE with Radeon 7770
http://ca.pcpartpicker.com/p/S9qg
http://ca.pcpartpicker.com/p/S9Iw
Prices are pretty much the same here in Canada for the CPU/GPU combo
Spend the extra $10 and get this http://ca.pcpartpicker.com/p/SacI
Gnash
April 21, 2013, 9:14pm
3
Ok but that doesn't answer my question on which performs better. That display seems fishy and more $$$ is needed for at least an extra case fan. Finally, that motherboard only support DDR3 1333+ (O.C.)/1066, NOT 1600.
Crossfire is a pain in the ass and dosent like working on some games the dedicated HD 7770 will be a better pick
1333+ so it will take 1600 you just clock it up in the bios (worth noteing The amd phenom is native to 1333Mhz to)
http://download.gigabyte.eu/FileList/Memory/mb_memory_ga-78lmt-s2p.pdf
So this is the only benchmark I came across that compared these two on similar games
http://www.tomshardware.com/reviews/a10-5800k-a8-5600k-a6-5400k,3224-16.html
http://www.tomshardware.com/reviews/radeon-hd-7770-7750-benchmark,3135-10.html
The a10 is running WOW on "good settings" with no aa, and the 7770 is running on Ultra with no aa and still achieving 15fps more at 1920x1080.
** Edit - See here for direct comparison . You should get better FPS using the x4 with the 7770 instead of the a10 with the 7770
Also, anything requiring cpu power, like Skyrim, will eat the a10 alive.
