A10-5800k or FX-6300
I have come up with two builds for my budget gaming computer with a max price of ~$550. One build has an A10-5800k while the other has a FX-6300. I have been recently playing games such as TF2, Dota 2, and Planetside 2, and I would want the builds to be at least able to play them pretty smoothly. I would want the build I pick to last me a while and I would probably upgrade them in their lifetime (definently on the A10-5800k).
Here are the builds: http://pcpartpicker.com/p/ovc9 and http://pcpartpicker.com/p/oveP.
I need your help deciding which one I should build.
Thanks!
You would definately see the differene if you got the 6300 build you would be able to run almost anything on ultra with good fps but if you just want something to play the games you listed get the 'A10 but don't expect to be playing anything to fancy but if It was me i would get the 6300 even if you don't have the cash now save it will make a HUGE difference.
Thanks! That is what most people have said too. I deffinently have the cash for it, I was just trying to save as much I can. I am planning on playing "tougher" games in the future also, so I will probably go 6300.
Go with the FX-6300 build, you're just going to regret getting the A10 when you have to lower the settings in every game to be able to play it.
