The Case :
EVGA DG-84 Gaming Case, 100-E2-1000-K0, Full Tower, K-Boost
Details
Type
ATX Full Tower
Color
Gunmetal Grey
Motherboard Compatibility
mITX/mATX/ATX/E-ATX
Side Panel Window
No
Dimensions & Weight
Max GPU Length Allowance
350 mm
Max CPU Cooler Height Allowance
175 mm
Dimensions (H x W x D)
25.29" x 10.63" x 27.01"
Weight
38.40 lbs.
Additional Info
Features
Optimized Airflow Path
Dedicated cooling path for graphics cards, giving ultimate cooling performance and increased clockspeeds.
Robust Water Cooling Support
Full support for dual 420mm or 360mm radiators give you ultimate cooling performance, with a dedicated section for mounting reservoir.
Cable Management
Dedicated cable management cutout points lets you keep your system layout clean, improving appearance and airflow.
K-Boost Button
Control your performance with EVGA K-Boost! One button boosts GPU and CPU clocks instantly, giving you ultimate control.
Removable Fan Filters
Easy to remove fan filters keeps your system dust free.
Easy Removable Door
Flip a switch to remove the entire door, making assembly as easy as can be.
GPU Airflow Channel
Adjustable channel to maximize cooling efficiency depending on your GPU setup.
Optional Segmented PSU Tray Hides Cables
Slidable tray keeps your system clean and hides Power Supply cables.
Flexible Fan Support
Supports up to 8 140 or 120mm fans.
Easy Access to I/O ports and Clean Cable Output
Cables exit on the back of the case, keeping cable management clean, and I/O ports are easily accessed by left door hinge.
Completely Removable PCI-E Brackets
Remove brackets to increase airflow or easily pass water cooling tubes.
The Cooling :
Phanteks PH-PWHUB_01 PWM Fan Hub
6 channel
2x PH-CB-Y3P fan splitter
11 fan max (additional splitters required)
Universal Mounting strips
Cougar CFT14SB4 140mm Case Fan
8 :
140mm
1000 64.5 / 109.6
Hyper-spin
17.9dB
be quiet! DARK ROCK PRO 3 Silentwings CPU Cooler 250W TDP
Fan Size
135mm
Bearing Type
Fluid Dynamic
RPM
1600-1999 RPM
Air Flow
65-70 CFM
Noise Level
20-25 dBA
Power Connector
4 Pin
Color
Black
Heatsink Material
Aluminum
The GPU:
SAPPHIRE NITRO Radeon R9 Fury 100379NTOC+SR 4GB 4096-Bit HBM TRI-X OC x 2 crossfired
4GB 4096-Bit HBM
Core Clock 1050 MHz
1 x Dual-Link DVI-D 1 x HDMI 3 x DisplayPort
Psu :
Corsair Rmx Series Rm850x 80 plus Gold full Modular
ATX12V / EPS12V
Full Modular
80 PLUS GOLD Certified
100 - 240 V 47 - 63 Hz
+3.3V@25A, +5V@25A, [email protected], [email protected], +5VSB@3A
Ram:
Gskills Ripjaws V 2x8
DDR4 3000 (PC4 24000)
Timing 15-16-16-35
Cas Latency 15
Voltage 1.35V
Motherboard:
Asrock Taichi :
AMD Promontory X370
Ryzen Series
DDR4 2667/ 2400/ 2133
Cpu:
AMD Ryzen 1700x
AMD SenseMI Technology
AMD XFR (eXtended Frequency Range) Technology
Socket AM4
Max Turbo Frequency 3.80 GHz
16MB L3 Cache
4MB L2 Cache
DDR4 Support
Unlocked Processor
Thermal Design Power 95W
Without Fan and Cooler
Os drive :
Corsair Force MP500 120g
Performance
Max Sequential Read
Up to 3000 MBps (ATTO)
Up to 2300 MBps (CDM)
Max Sequential Write
Up to 2400 MBps (ATTO)
Up to 1400 MBps (CDM)
4KB Random Read
Up to 150,000 IOPS
4KB Random Write
Up to 90,000 IOPS
https://pcpartpicker.com/user/Freaksamcker/saved/yNy23C
This is how it ended after having a bad stick of ram and the Corsair psu die after three weeks of stock running.
