A nagging question
I have a very nagging question...
Should I spend more on CPU and less on GPU?
For instance, in my situation, the most amount of money is in my GPU (MSI 760 Twin Frozr @ $260) and less in my CPU (FX 6300 @ $110). Should I buy an i5 3570k or maybe a Haswell i5 4670k and replace my GPU with a GTX 660 or something that keeps my budget around $750.
As of now, here's my build- http://pcpartpicker.com/user/TrivTrav/saved/1Zxy
and here's my Intel build that I'm contemplating- http://pcpartpicker.com/user/TrivTrav/saved/2qYJ
I need your help on deciding this.
You could perhaps get an i5 2500k for around $150. The 3570k is only a bit faster than the 2500k, even less so in gaming applications. Also when overclocked the 2500k will easily defeat the 3570k.
I highly doubt that there's such a place where it is possible.
Anyway, it depends on your usage patterns. For gaming GPU is clearly way more important. If you don't care about graphics that much or you don't play a lot of GPU-intensive games, intel build is better.
Ebay, Gigabuster is doing it.
Yes- you want to spend (for gaming) more money into you GPU because that is more directly related to your fps than your cpu. the 3570k and 760i are a good combo. and another thing is that hawswell (4670k) doesn't offer much performance increase. you're paying for power efficieny and potentially redering instruction sets built in.
Yes I forgot to make myself clear in one portion of my post- This will be a gaming only build. Heavy games such as DayZ, Battlefield, Arma II, Arma III, and Minecraft.
