Just making sure I understand this correctly, the guest GPU renders into its framebuffer which is then copied over PCIe into system memory and then into the host GPU?
So 1920*1080 * 60 fps * 32 bpp equals just under 4GB/s ((1920*1080*60*32 )/ (1024^2))
Unless I have done my math wrong that’s some serious bus saturation, this sounds incredibly expensive to do so what did I miss?
Yes and it gets resampled, default is just pixel halving or doubling, but mipmaps can be turned on which generates a nicely scaled window. See my original screenshots up top
The guest is running 1920x1200
Those that care can actually open that image up full size and sneak a peek at the client (host) code.
@wendell I spoke with one of the engineers at VMWare about seamless mode and the summary was based on their analytics nearly nobody uses it so it isn’t worth investing into at all since it is relatively complex to develop and support.
Well good news, I believe we can do this too in time (version 2.0 perhaps). Once the source is out there it will open it up for everyone to hack in their favorite features, I would expect development progress to increase exponentially.
@gnif I chucked 50 upside-down Australian dollarydoos your way in the hopes it helps you get to a 1.0 release. Will probably convert into fuck all, but money where your mouth is and all that. I hope you reach your goal mate
I haven’t contributed to kernel dev before (I’d like to pick this up in future… it’s an area of interest) but it’s surprising (to me at least) that your original commit isn’t merged in with author credit going to you? Seems like a squash/rebase on his end… I suppose this is “normal”?
Here’s a favour, if/when you have time. I’d appreciate a ‘newbies’ guide on how to contribute to kernel dev - not so much on ‘how to code’ but rather, the workflow, etiquette, how NOT to piss Linus off.
I can reflog with the best of 'em, so that’s not a pain point (personally for me) but, given we like to spread-knowledge here aimed at all levels, if you could post this thread taking a ‘wider’ audience into account, and maybe structuring it as such, that would be epic.
Also, your workflow on how you manage recompiling various kernel versions, and staying organised would be helpful too. I’d imagine that you have to run through the usual rigamarole of -
compile new kernel
update grub
update initramfs (dracut magic in Fedora) (if needed)
anything else I’ve missed?
I has been a long time since I’ve gotten into this side of things…
