A less than 8.5 inch wide 4 x 3.5" hdd mini itx case?
I’m looking to build two small 4 drive storage server boxes that will fit side by side in a 19" server rack.
I recently stuffed an asrock j3455-itx and 4 x 3.5 inch drives into an old fractal array r2 case I had lying around. Excellent little system, sips power, does everything it needs to do, except being about an inch wider than half a 19" rack shelf.
I’ve looked at a bunch of mini itx cases online and all the 4 drive ones seems to be slightly wider than 8.5".
I’ve considered going with something like a qnap tr004 das hooked up to a thin client, but tr004’s are pretty expensive for what they are and I don’t fancy running storage over usb.
I tried my luck with a qnap ts459 but it died to the intel bug and the resistor trick didn’t fix it.
So why don’t I just grab a 4 bay synology off ebay? Well, I’ve been running debian and ubuntu servers for 15+ years and I’m not ready to commit to proprietary software. One plus of the ts459 was that it ran standard debian before dying.
Back to my main question, any of you guys know about a mini itx case that holds 4 drives and is less that 8.5" wide?
Bit of a lame suggestion because you can only get them second-hand now, but I found the Lian Li Q25 to be a good compact Mini-ITX NAS case, they have 5x 3.5 hotswap bays and can take an extra two SSDs or HDDs screwed to the bottom. You can get them in silver (Q25) and black (Q25B).
I measured one of mine:
  • 198mm (<7.8") wide
  • 280mm (<11.1") tall
  • 360mm (<14.2") deep
https://www.newegg.com/p/N82E16811112339
Most compact and well-made NAS case I’ve found, so perhaps still worth searching out.
Thanks for the suggestion, however I ended up with a Jonsbo N1 that fits the bill perfectly.
How’re temperatures of the drives and CPU, and which drives do you use?
Main concern about these sorts of small cases is always temps for me.
The drives are wd40efzx 4 tb WD Red Plus mounted in slot 1, 2, 4 and 5 with a one drive gap in the middle. HDD temps are 27C on two of them and 26C on the two others, and the CPU’s are currently running 33C with a min of 29C and a max of 40C, CPU is a Celeron J3455.
I used to run the system in a Fractal Array R2 case with a 140mm fan before moving it to the Jonsbo N1 and it ran roughly 2C colder.
OS is Ubuntu server and I only use the system for storage, no virtualization or other fancy stuff, I’ve got other servers for that.
Power consumption wise it’s 25W average, 29W max, measured over the last 48 hours running 24/7.
Wow that’s pretty good. I was thinking of doing something like this for a Proxmox backup server / ZFS replication backup target, this seems to be a good build for this.
I’m very happy with mine, I’m running with the standard fan but removed the decorative steel plate on the front to allow better airflow - not sure it was needed, but since it looks fine without the plate I removed it. Very low noise, just a bit of hdd hum when I put my ear to the chassis.
Another thing I really like is that it’s not super cramped inside making it an easy build.
This topic was automatically closed after 273 days. New replies are no longer allowed.
