So this might be a bit open ended but I will give it a try. I figure this is the place to get the hardware geek’s input I currently have a kensington SD5550t which is a thunderbolt 3 dock with 65w of power output. It’s been working fine with my 2 linux laptops (work / personal) and I just move the cable between them as I want to change.
Now I am on the waitlist for a framework 16 which should come in Q1 and they suggest a 100w power adapter (I don’t have the gpu module yet at least). So that means my current dock is going to fall short therefore I figured now’s a good time to jump to TB4. Can anyone recommend a good TB dock that will provide at least 100w of power and has 2 display outputs? Ideally both DP but I can do one as usb c or hdmi too.
I assume there’s no tb dock that would provide the full 180w recommended or 240w of PD3.1?
