A good case ( max $120)
i would like to know what is a good case whit a max of $120 ?
i thought about the corsair carbide series 500R
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352021
They have white and titanium grey colour if you prefer them and you can get the non windowed version for $10 less if thats what you prefer. Has great space for all sizes of graphics cards, cooling is amazing, their sound cancelling foam is so good if your a silent freak and their cable managment is also good.
If you dont like the look go for this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139013
This has basically all the features you would expect and with that beast of a look.
where do you plan on buying from?
500r is a nice case though.
others to consider:
CM690 II
Bitfenix Shinobi (or if you can stretch you budget just a little the XL model)
Antec P280 (probably the only Antec case in their range that ticks all the boxes)
Fractal Design R4
NZXT Phantom
Can't go wrong with a Fractal Design R4.
But... I love Cooler Master and their cases. Especially the Storm Trooper and the Storm Stryker.
In my next build I'll be grabbing the Cooler Master Storm Stryker <3!
http://www.amazon.com/CM-Storm-Trooper-Computer-SGC-5000-KKN1/dp/B005P7XSV6/ref=sr_1_4?ie=UTF8&qid=1367859564&sr=8-4&keywords=storm+stryker
The Phantom is a good choice to look at.  The airflow on that case is insane, just make sure you get extra fans for the top and front (and side if you have room).
I dont even need to say anything but listen to Aussie, he reccommended exactly what i would have +10
