Hello forum! I sort of have a few questions on a build that I use. Let me start off by listing what the specs of my PC are currently.
GPU: MSi Radeon 7870 HAWK
CPU: AMD Phenom 965 II x4 Black Edition
RAM: 8gb of DDR3 1600 MHz
I was wondering if this could run BF4 at like high with good FPS (like 60+). Also, when the time rolls around (Christmas) I am thinking about upgrading, I will have a $400 budget at Christmas time. Do you think I should get a better CPU or GPU to play these new games such as BF4? Thank you for your time if you read this, I would really appreciate some feedback from you wonderful people.
Add another 7870 and you should be golden. You might notice some bottlenecking with the Phenom II X4, though. I would consider upgrading to at least an X6 at your earliest convenience.
That is what I was planning on doing, I was going to upgrade to an 8350 at Christmas time. I will still probably have enough for another 7870, but my 7870 is discontinued ;___;
The 7870s are still available at a lot of retailers. I do believe you can crossfire the HD 7870 and an R9 270X, as they're basically the same card. 7870s are usually cheaper, though.
If you have a motherboard that is FX compatible (not all older mobo's are) I would get a FX6300 six core to go with your 8GB RAM and then another 7870 to xfire, or 280x as mentioned.
Yeah, and make sure your motherboard is up to par for the power draw of the FX-8350. You need pretty decent cooling and VRMs to make sure your motherboard doesn't die on you.
