So i've been googling around for benchmarks of the 8350 vs the 3570k / 3770k for my next build. I've been seeing a lot of biased reviews without proper benchmarking scales / graphs / comparisons. Does anyone have an unbiased, maybe even personal, review or opinion on the 8350?
Currently this is the build I have set up. I've already purchased the case and the cpu cooler, an extra fractal design 140mm fans (3 extra) and the drives (ssd and hdd)
This looks like a well thought out system that will be very nice. I am fairly sure that the 8350 is slightly better than the i5 3570k and can overclock like a beast. I would spend a little more on a corsair watercooling system so that you do have that overclockability. the only other thing is to get a 120gb ssd and a 1tb hdd instead of two 60gb ssd's and two 500gb hdds, you can always partition them if you realy want, the larger drives will also most likely a bit faster. I would buy a 120 gb hyperx 3k ssd from kingston and a 1tb western digital green drive. if you want the two hard drives for backup howerver, go for it.
I had an idea with those drives, just to raid the ssd's together, and the hdd's together to get the performance. raid 0 ssd...amazing read/write. Also, take a gander at the link below. I did some research on the h100, h100i and some comparable air coolers. The noctua dh14 is the best performing air cooler, and is much quieter, though that's not the one I chose, as i went for the thermalright. I also really like big heatsinks...don't ask lol. But, as you can see in that benchmark, there is only a 5c difference...honestly not that bad AT ALL. Also, there are people that have been getting 5ghz on air all over overclock.net
Yes sir, the ssds are for raid. A-data was a personal choice, maybe not a smart one. edit: I just checked newegg and I can cancel my order right now, so i'm going to so that I can get some more advice from you all. I'm just going to get the case and fans. Also, I will change that memory too. I didn't read the description, that it was 4x4gb. Also, take a look at this:
