Ha wut?
Ha wut?
sorry not being descriptive but i meant to say was that what brand and models under 100 each or good enough to connect next to one another
You won't find any decent 1080p monitors less than $120, unless you're fine with purchasing used/refurbished ones.
I would just go with one Korean 1440p screen.
https://teksyndicate.com/news/2013/08/15/tek-syndicate-1440p-monitor-club
I wouldn't buy 3 cheap monitors. You could get 3 descent monitors for $160 but I wouldn't go cheaper than that. If you cant afford that start with one or two and and add on when you have more money to spend.
great suggestion thank you
