Looks good to me. You might want to get a 650 watt psu, but the 500 watt would probably be sufficient enough for that build.
I'm wondering how well the H60 actually performs too. I would check out some reviews and see if there are any better coolers for the money. I have a sneaking suspicion that the Cooler Master V6 GT would outperform it, and it's only around $46 on newegg.
You could probably get a 7870 instead of the 7850 and still be within your price range too.
Western Digital Caviar Black WD5002AALX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive-94.99
PowerColor AX7950 3GBD5-2DH Radeon HD 7950 3GB 384-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card-349.99 - $20 mail in rebate
FSP Group AURUM GOLD 650W (AU-650M) ATX12V/EPS12V Modular Flat Cable, 80 PLUS GOLD, SLI and AMD CrossFireX Certified Compatible ...144.99 - $15 mail in rebate
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B-53.99
ASRock Fatal1ty P67 Performance LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard-99.99
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX-109.99
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...-29.99
OCZ Vertex 3 VTX3-25SAT3-120G 2.5" 120GB SATA III MLC Internal Solid State Drive (SSD)-94.99 - $15 mail in rabate
all together that is $1,038.91 before mir
and about 980 of mir and the performance is much better
