9800gtx+ fan?
Hi guys just wondering if there is a way to hook up my GPU fan to my mobo/psu so it will run at 100% all the time
Cheers
Spankks
Get rivatuner and set the GPU fan speed @ 100%
as simple as this.
im getting a error message "statistics server is currently active installation aborted" what do i do?
Use EVGA Precision
my fan never goes too 100% with that
can i use evga precision if i have a bfg card?
Just manually crank it using the EVGA software or RivaTuner and your set
EDIT:Â O and your dont need 100%....atleast go with 70
its needs 100 for the OC i have on it
You dont say..well ya crank it then
yea but evga drops the fan speed sometimes and im gettin an error message from riva tuner (above)
Try reinstalling your drivers or getting the latest ones if you haven't already and then also reinstall the EVGA software.
Yeah try reinstalling the drivers, and if you manage to install RivaTuner;
i got rivatuner installed but it did the same droped the fan speed on startup so i have to make it 100% again so ill just stick with EVGA for now
