Can someone tell me some vga coolers (or whatever you call them) that would fit on the "smaller" sized 9800gtx+, because my card tends to get quite hot. I've checked on newegg but some vga coolers that say they will fit on the EVGA 9800gtx+ do not actually fit, I believe because there is larger gtx+ and a smaller gtx+ model.
Honestly, I'm just confused as hell. If anyone could clear this up and/or sugget me some coolers that would be great. Thanks and cheers.
Well emailing the company will work. but some companies take forever to reply. I dunno if what you want to do is worth it. I mean idk which branded 9800 GTX + you have, but a cooler is usally around 40. I mean if you should your current 9800 GTX + and added the money whcih you were going to spend the money on, you could get a new 9800 GTX + or maye even a better card. Not to mention you avoid the hassle of install, and voiding warranty unless you have evga
Have you tried upping the Fan speed on your 9800? I know when I was running 2 of those in SLI they did tend to get worm. I noticed a big difference upping fan speeds on 2 8800GT's back in the day.
