970 chipset and fx 8320
Will the amd motherboards with the 970 chipset work with the FX 8320? or will I have to do bios updates?  I will not be doing any overclocking... oh and next to the board in the memory that it is compatible with, it says 1866/OC 1600/1333/ etc...  what does the oc mean, if you don't overclock the memory it will run @ 1600mhz...
Thanks for all your help
My old 970 chipset worked with my 8350, so it should work with an 8320. Buy an asus board, then if you do need an update it's stupidly easy to do
I have the gigabyte 970a ds3 which has a 970 chipset and I can assure you that it is compatible. However make sure your board has decent power delivery, although this board can support it, it would most likely fry after a minute due to the 4+1 power phase
yes well if you can find a Asus M5A97 evo R2.0 fpr cheap 6+2 powerphase and digi vrm, this board supports an 8 core without problems, but they are hard to find, outside europe
+1 to that board. Have that with the FX8350. Really great setup for the price. Plus there was no need for me to flash the BIOS. Worked out of the box.
Funnily enough,This board is the ONLY good 970 AM3+ board here in Singapore. The next up the line here is the Sabertooth. MSI and Gigabyte,as far as i can tell,are slowly dropping support for the AM3+ board
This gigabyte 970 board has a 8+2 power design so i wouldn't really be afraid of it frying but I keep hearing bad things about the gigabyte AMD boards so idk if it is actually recommendable. You might take some time and research it if you cant find that particular asus board.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128651
I have an 8320 and a Gigabyte 970a D3P and they work together without any problems. I even have my 8320 running at 4.2 ghz although I plan on upgrading to an ASUS m5a99fx pro r2. If you're not overclocking, you shouldn't have any problems
I am running my FX-8320 on a 760g chipset at stock so, I mean yeah you can do it.
wow, thanks so much for all the info...that's awesome
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131873
Wasn't hard for me to find :P
I keed I keed
Wrong! Thats not the EVO. haha ☺
