9600-24i - mpi3mr error on passthrough
Hi all,
I’m trying to pass through a 9600 on Proxmox.
Firmware updated to: 9600_24i_Pkg_8.13.1.0
Some older posts talked about driver on proxmox and/or the linux/truenas vm, but there drivers are now on way later versions.
I have also updated the proxmox kernel module to the latest and also blacklisted the module and pci-id from proxmox as an extra step. In all cases the error inside the VM is the same.
I have used older LSI cards with no issues for years b=now, but its my first time with a 96XX card.
  • Linux VM Passthrough (Truenas Scale - 2504)
[ 0.609147] Loading mpi3mr version 8.12.0.0.50
[ 0.609155] mpi3mr 0000:06:10.0: osintfc_mrioc_security_status: PCI_EXT_CAP_ID_DSN is not supported
[ 0.609701] mpi3mr 0000:06:10.0: Driver probe function unexpectedly returned 1
  • On PROXMOX (seems all ok. prox fully upgraded):
root@:~# dmesg |grep mpi3
[ 1.036355] Loading mpi3mr version 8.9.1.0.51
[ 1.036414] mpi3mr0: mpi3mr_probe :host protection capabilities enabled DIF1 DIF2 DIF3
[ 1.036425] mpi3mr 0000:01:00.0: enabling device (0000 → 0002)
[ 1.044895] mpi3mr0: iomem(0x000000f812c00000), mapped(0x0000000006c26cfa), size(16384)
[ 1.044898] mpi3mr0: Number of MSI-X vectors found in capabilities: (128)
[ 1.044899] mpi3mr0: ioc_status(0x00000010), ioc_config(0x00470000), ioc_info(0x00000000ff000000) at the bringup
[ 1.044902] mpi3mr0: ready timeout: 510 seconds
[ 1.044904] mpi3mr0: controller is in reset state during detection
[ 1.044915] mpi3mr0: bringing controller to ready state
[ 1.149709] mpi3mr0: successfully transitioned to ready state
[ 1.153237] mpi3mr0: IOCFactsdata length mismatch driver_sz(104) firmware_sz(112)
[ 1.153456] mpi3mr0: ioc_num(0), maxopQ(127), maxopRepQ(127), maxdh(1023),
[ 1.153457] mpi3mr0: maxreqs(8192), mindh(1) maxvectors(128) maxperids(1024)
[ 1.153458] mpi3mr0: SGEModMask 0x80 SGEModVal 0x80 SGEModShift 0x18
[ 1.153459] mpi3mr0: DMA mask 63 InitialPE status 0x20 max_data_len (1048576)
[ 1.153459] mpi3mr0: max_dev_per_throttle_group(0), max_throttle_groups(0)
[ 1.153460] mpi3mr0: io_throttle_data_len(0KiB), io_throttle_high(0MiB), io_throttle_low(0MiB)
[ 1.153463] mpi3mr0: Changing DMA mask from 0xffffffffffffffff to 0x7fffffffffffffff
[ 1.153464] mpi3mr0: Running in Enhanced HBA Personality
[ 1.153464] mpi3mr0: FW version(8.13.1.0.0.1)
[ 1.153465] mpi3mr0: Protocol=(Initiator,NVMe attachment), Capabilities=(RAID,MultiPath)
[ 1.165093] mpi3mr0: number of sgl entries=256 chain buffer size=4KB
[ 1.166701] mpi3mr0: reply buf pool(0x0000000008506db3): depth(8256), frame_size(128), pool_size(1032 kB), reply_dma(0xfdc00000)
[ 1.166703] mpi3mr0: reply_free_q pool(0x00000000f2902dd4): depth(8257), frame_size(8), pool_size(64 kB), reply_dma(0xfdbe0000)
[ 1.166704] mpi3mr0: sense_buf pool(0x0000000059f704fe): depth(2730), frame_size(256), pool_size(682 kB), sense_dma(0xfdb00000)
[ 1.166705] mpi3mr0: sense_buf_q pool(0x000000007a569f8a): depth(2731), frame_size(8), pool_size(21 kB), sense_dma(0xfdaf8000)
[ 1.177815] mpi3mr0: firmware package version(8.13.1.0.00000-00001)
[ 1.179251] mpi3mr0: MSI-X vectors supported: 128, no of cores: 16,
[ 1.179252] mpi3mr0: MSI-x vectors requested: 17 poll_queues 0
[ 1.191237] mpi3mr0: trying to create 16 operational queue pairs
[ 1.191237] mpi3mr0: allocating operational queues through segmented queues
[ 1.236036] mpi3mr0: successfully created 16 operational queue pairs(default/polled) queue = (16/0)
[ 1.238956] mpi3mr0: controller initialization completed successfully
[ 1.239510] mpi3mr0: mpi3mr_scan_start :Issuing Port Enable
[ 1.240214] mpi3mr0: Enclosure Added
[ 1.242416] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 1.242648] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 1.242877] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 1.243109] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 1.243345] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 1.243573] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 1.243801] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 1.244041] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 1.244271] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 1.244500] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 1.244732] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 1.244969] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 1.245205] mpi3mr0: PCIE Enumeration: (start)
[ 1.245445] mpi3mr0: PCIE Enumeration: (stop)
[ 1.245677] mpi3mr0: PCIE Enumeration: (start)
[ 1.245904] mpi3mr0: PCIE Enumeration: (stop)
[ 1.246136] mpi3mr0: PCIE Enumeration: (start)
[ 1.246374] mpi3mr0: PCIE Enumeration: (stop)
[ 1.246607] mpi3mr0: PCIE Enumeration: (start)
[ 1.246841] mpi3mr0: PCIE Enumeration: (stop)
[ 1.247077] mpi3mr0: PCIE Enumeration: (start)
[ 1.247306] mpi3mr0: PCIE Enumeration: (stop)
[ 1.247545] mpi3mr0: PCIE Enumeration: (start)
[ 1.247779] mpi3mr0: PCIE Enumeration: (stop)
[ 2.413848] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 2.413858] mpi3mr0: Device Added: dev=0x0009 Form=0x0
[ 2.414065] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 2.414071] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 2.414681] mpi3mr0: Device Added: dev=0x0007 Form=0x0
[ 2.414696] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 2.414698] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 2.414928] mpi3mr0: Device Added: dev=0x0003 Form=0x0
[ 2.415206] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 2.415215] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 2.415480] mpi3mr0: Device Added: dev=0x0006 Form=0x0
[ 2.415757] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 2.415767] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 2.416042] mpi3mr0: Device Added: dev=0x0005 Form=0x0
[ 2.416299] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 2.416301] mpi3mr0: SAS Discovery: (start) status (0x00000000)
[ 2.416570] mpi3mr0: Device Added: dev=0x0008 Form=0x0
[ 2.416852] mpi3mr0: SAS Discovery: (stop) status (0x00000000)
[ 2.417125] mpi3mr0: Device Added: dev=0x0004 Form=0x0
[ 2.427298] mpi3mr0: port enable is successfully completed
root@:~ /opt/MegaRAID/storcli2/storcli2 /c0 show personality
CLI Version = 008.0013.0000.0007 Mar 13, 2025
Operating system = Linux6.8.12-10-pve
Controller = 0
Status = Success
Description = None
Personality Information :
Prop Description
Controller Personality eHBA
Available Personality Information :
ID Name IsCurrent IsRequested IsMutable IsMutableWithForce
0 eHBA Yes No Yes Yes
root@: lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 7T 0 disk
sdb 8:16 0 7T 0 disk
sdc 8:32 0 7T 0 disk
sdd 8:48 0 7T 0 disk
sde 8:64 0 7T 0 disk
sdf 8:80 0 7T 0 disk
nvme0n1 259:0 0 3.6T 0 disk
├─nvme0n1p1 259:1 0 1007K 0 part
├─nvme0n1p2 259:2 0 1G 0 part /boot/efi
├─nvme0n1p3 259:3 0 299G 0 part
│ ├─pve-swap 252:0 0 32G 0 lvm [SWAP]
│ ├─pve-root 252:1 0 78.7G 0 lvm /
│ ├─pve-data_tmeta 252:2 0 1.7G 0 lvm
│ │ └─pve-data-tpool 252:4 0 168.8G 0 lvm
│ │ ├─pve-data 252:5 0 168.8G 1 lvm
│ │ └─pve-vm–121–disk–0 252:6 0 32G 0 lvm
│ └─pve-data_tdata 252:3 0 168.8G 0 lvm
└─nvme0n1p4 259:4 0 3.3T 0 part /mnt/Storage
01:00.0 RAID bus controller: Broadcom / LSI Fusion-MPT 24GSAS/PCIe SAS40xx (rev 01)
Subsystem: Broadcom / LSI eHBA 9600-24i Tri-Mode Storage Adapter
Flags: bus master, fast devsel, latency 0, IOMMU group 14
Memory at f812c00000 (64-bit, prefetchable) [size=16K]
Expansion ROM at de400000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Capabilities: [48] MSI: Enable- Count=1/32 Maskable+ 64bit+
Capabilities: [68] Express Endpoint, MSI 00
Capabilities: [a4] MSI-X: Enable+ Count=128 Masked-
Capabilities: [b0] Vital Product Data
Capabilities: [100] Device Serial Number 00-80-5c-eb-cd-30-ad-1d
Capabilities: [fb4] Advanced Error Reporting
Capabilities: [138] Power Budgeting <?> Capabilities: [db4] Secondary PCI Express Capabilities: [af4] Data Link Feature <?>
Capabilities: [d00] Physical Layer 16.0 GT/s <?> Capabilities: [d40] Lane Margining at the Receiver <?>
Capabilities: [160] Dynamic Power Allocation <?>
Kernel driver in use: mpi3mr
Kernel modules: mpi3mr
Are the motherboard’s UEFI settings…
  • CSM disabled?
  • IOMMU Enabled (not just “Auto”)?
  • Ten Bit Tag Support Enabled?
thanks for taking the time.
Ill check what tenbit tag is but the other two were correct.
I did manage to solve it, it was power saving options on PCI. reset them and it was ok.
Thanks for mentioning PCIe Power Management being the cause of the issue, that information might be helpful for others!
