I need a build that can run metro 2033 on high DX11 at 40 fps stable (no physx or Tess)
I also need a 1080p monitor because this is my first build so really the budget is like 800$ USD
Thankyou in advance
Thankyou in advance
Well, I'm a bit confuzzled to say the least. Just to clarify, what is your budget for everything? $920?
If the budget is $800 for the tower itself and the components within, then use this as a base build...
[url=http://pcpartpicker.com/p/qI0p]PCPartPicker part list[/url] / [url=http://pcpartpicker.com/p/qI0p/by_merchant/]Price breakdown by merchant[/url] / [url=http://pcpartpicker.com/p/qI0p/benchmarks/]Benchmarks[/url]
[b]CPU:[/b] [url=http://pcpartpicker.com/part/intel-cpu-bx80637i53570k]Intel Core i5-3570K 3.4GHz Quad-Core Processor[/url] ($214.99 @ Amazon)
[b]CPU Cooler:[/b] [url=http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2]Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler[/url] ($29.98 @ Amazon)
[b]Motherboard:[/b] [url=http://pcpartpicker.com/part/asrock-motherboard-z77extreme4]ASRock Z77 Extreme4 ATX LGA1155 Motherboard[/url] ($119.98 @ Outlet PC)
[b]Memory:[/b] [url=http://pcpartpicker.com/part/gskill-memory-f31600c9d8gab]G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory[/url] ($37.99 @ Newegg)
[b]Storage:[/b] [url=http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex]Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive[/url] ($69.99 @ NCIX US)
[b]Video Card:[/b] [url=http://pcpartpicker.com/part/his-video-card-h787f2g2m]HIS Radeon HD 7870 2GB Video Card[/url] ($219.98 @ Newegg)
[b]Case:[/b] [url=http://pcpartpicker.com/part/cooler-master-case-rc912kkn1]Cooler Master HAF 912 ATX Mid Tower Case[/url] ($49.49 @ SuperBiiz)
[b]Power Supply:[/b] [url=http://pcpartpicker.com/part/corsair-power-supply-cx500]Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply[/url] ($39.99 @ Newegg)
[b]Total:[/b] $782.39
[i](Prices include shipping, taxes, and discounts when available.)[/i]
[i](Generated by PCPartPicker 2012-12-03 02:48 EST-0500)[/i]
The way in which this site converts BBCode is not what I'm used to, so you can just click on the highlighted "PCPartPicker" link to view a more detailed and easier list to follow.
Amd Processor option?
What do you plan on using this build for exactly?
[url=http://pcpartpicker.com/p/qIhQ]PCPartPicker part list[/url] / [url=http://pcpartpicker.com/p/qIhQ/by_merchant/]Price breakdown by merchant[/url] / [url=http://pcpartpicker.com/p/qIhQ/benchmarks/]Benchmarks[/url]
[b]CPU:[/b] [url=http://pcpartpicker.com/part/amd-cpu-fd6300wmhkbox]AMD FX-6300 3.5GHz 6-Core Processor[/url] ($129.99 @ Microcenter)
[b]CPU Cooler:[/b] [url=http://pcpartpicker.com/part/cooler-master-cpu-cooler-rrb10212pg1]Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler[/url] ($23.99 @ SuperBiiz)
[b]Motherboard:[/b] [url=http://pcpartpicker.com/part/asrock-motherboard-970extreme4]ASRock 970 EXTREME4 ATX AM3+ Motherboard[/url] ($99.99 @ Amazon)
[b]Case:[/b] [url=http://pcpartpicker.com/part/corsair-case-200r]Corsair 200R ATX Mid Tower Case[/url] ($29.99 @ Newegg)
[b]Total:[/b] $651.91
[i](Generated by PCPartPicker 2012-12-03 04:07 EST-0500)[/i]
If you go with the AMD option, that'll allow you to allocate more funds to the GPU. I'd recommend stepping up the GPU to a HD 7950. Or if you're an nvidia fan, you can get the GTX 660 Ti. The HD 7970 and GTX 670 would be excellent choices as well; although, those GPUs come with a heftier price tag.
This was like 780$ two days ago but, http://pcpartpicker.com/p/qql9.
no bottlenecks in this build?
Nope, you're good to go.
