$910 PC build. Need advice if it is good
http://pcpartpicker.com/p/1dX01
Here is my PC parts I have picked. I was wondering if the motherboard I picked will go well with the cpu and the gpu I picked and also the powersupply has enough wattage. Also did I pick the best cpu cooler? Is it better to have a fan or a hydro pump cooler? As for the case, I picked a random one because I will be picking it up from a local retailer instead of getting it online.
Thanks for your help.
is this for gaming, video editing, what?
Its for everyday use (browsing internet, downloading, using microsoft office like ppt, word). Also it is for gaming as well but I dont mind if I can play at the highest settings. I just want a overall good PC that can do everything. Maybe later on I will be video editing but not to much editing either. Thanks for the reply
I meant to say I dont mind if I can't play at the highest settings.
http://pcpartpicker.com/p/1dZrY
Hey is that what you have if not can you tell me why you recommend that over mine?
