I Originally was going to build a $1000 PC, but I wanted to scale it back a bit. This is my build so far. I don't mind the price its at, and it is going to be cheaper because I'm using Micro Center and the one located in Michigan (different prices for different stores). For example, the FX-8350 $30 less at Micro Center. So if you revise its fine to go over budget because Prices are typically lower.
http://pcpartpicker.com/p/L3J4
http://cart.microcenter.com/cart.aspx
https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=20298005
I also split the build up between NewEgg and Micro Center because Mirco Center doesn't have everything that I need. So the 2 links contain all the parts.
