900$-ish (800€) build for gaming
I have been looking to build a gaming PC a bit under the 900$ and i was very interested in the GTX 960. The problem is that prices are way higher in Europe and i need Windows because of my parents that don't want me to crack it. The problem is every build i find are above budget (around 850€).
PS : Windows 8 costs 115€ in France so it makes around 125$ which leaves 775$ for hardware. Also i already have a monitor, a keyboard and a mouse.
Two things.
What games do you wanna play?
And can you link us a few websites you might buy from? PC part picker does not seem to have a french version.
A few questions:
Are you a student? Cause you can get a student version of windows for a far better price (costs 60€ here). Also do you need a case and storage?
I want to play tha latest games like Farcry 4 or The Witcher 3 at least at medium settings. As i am French, you have sites like LDLC, TopAchat or materiel.net
Well, i don't know if a highschooler counts as a student
Could count as the same, some countries count it as the same, some don't. Doesn't hurt to ask
Get an OEM license for Windows, or buy a key of someone who bought in bulk. I once got a key for E20 in the Netherlands.
As far as hardware is concerned, I'm only familiar with the Dutch Tweakers.net which allows you to make wishslists and the prices probably come closer to yours there.
Okay, i will look for that
I checked if a highschooler is considered as a student and the answer is "no". I found the conditions on microsoft's store website : http://www.microsoftstore.com/store/msca/en_CA/html/pbPage.StudentStoreTermsandConditions. I share the english version but it's exaclty the same in french
I will post the current config that i selected :
CPU : Intel Core i5 4460 199.90€
MB : Asus H81-PLUS 78.80€
RAM : DDR3 Kingston HyperX Fury Red 2x4 GB, 1600 Mhz, CAS10 64.80€
GC : Zotac GeForce GTX 960 OC, 2GB 215.90€
HDD : Western Digital Caviar Blue, 1TB 58.90€
OD : Asus DRW-24F1ST, Black 16.90€
Case : BitFenix Neos, Black/Black 44.80€
PSU : Corsair VS450, 450W 42.90€
OS : Microsoft Windows 8.1, 64 bits
Total : 837.80€
(config made using www.topachat.com Config'O'Matic)
Here, can you tell me if the configuration is good and if possible a way to lower the price a bit ?
I just thought of something, can I recover an old computer's optical drive ? Because it'll only be used to install Windows and nothing else so it would be a waste to buy one.
If i remove the SSD, yes there's room for Windows but i know AMD's FX processors are really old so wouldn't it be better to have an Intel processor ?
AMD FX-6300 3.5GHz 6-Core Processor
$94.89 Buy
CPU Cooler
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
$27.98 Buy
Motherboard
Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard
$104.99 Buy
Memory
Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1866 Memory
$59.99 Buy
Storage
Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
$97.89 Buy
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
$48.75 Buy
Video Card
Sapphire Radeon R9 280 3GB Dual-X Video Card
$149.20 Buy
Case
Corsair 200R ATX Mid Tower Case
$47.99 Buy
Power Supply
EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply
$64.99 Buy
Optical Drive
Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
$18.89 Buy
Total: $715.56
Well, even with an AMD based build, the price stays the same. Again, i said the parts cost higher in France than in the US. In fact, in France, they manage to not change the numbers but only the currency so in the US. For example, when you see an Intel processor at 200$ in the US, the same Intel processor will cost 200€ in Europe even if there's a difference of currency.
Use windows 10 preview as os, its free, and when the full version releases just get it for free, it would really be a waste to buy an os now.
http://windows.microsoft.com/nl-nl/windows/preview-iso
MSI GeForce GTX 960 GAMING 100ME 214 euro
Crucial Ballistix BLS2CP4G3D1609DS1S00CEU 54 euro
Cooler Master N300 35 euro
Seagate Desktop HDD ST1000DM003 50 euro
Cooler Master Hyper 212 EVO 30 euro
Thermaltake Smart SE 530W 60 euro
Intel Core i5-4690K 240 euro
Gigabyte GA-Z97X-SLI 117 euro
Windows 10 0 euro
total 800 euro
I think Microsoft thought of it. It won't be that simple. I don't think you'll be able to get Windows 10 for free if you download the preview otherwise everybody would have done it already.
It is excactly that simple.
Just go to the site and sign up.
